Electronics Cold Cathode Controller
Discussion in 'Modding' started by BasicBubbleHJK, 8 Jun 2003.
  1. BasicBubbleHJK
    BasicBubbleHJK What's a Dremel?
    4 Feb 2003
    can any one see any problems with this circuit?
    does the mobo header need a protection diode because the relay is an inductive load? if so what type should i use.
    I think teh header should be ok, as fans are inductive as well
    thanks
    link if pic doesnt work
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Yes, add the diode. 1N4148 or 1N4001 will do.
    I can't see any problems, but why? Isn't the fan header on all the time? :confused:
  3. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    The fan headers on some botherboards can be controlled by software I believe.
  4. star882
    star882 What's a Dremel?
    19 Mar 2003
    Not in all systems.
  5. BasicBubbleHJK
    4 Feb 2003
    when my system goes into suspend the fan headers go off, but the molexes dont, and my cathode is keeping me awake :sigh: so this circuit swill turn the cathode off when the comp goes into suspend.
    Where does the diode go? in series with the relay coil?
  6. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Aha... a cunning plan :clap:
