Case Mod - In Progress Cold Eye - A CASE CON
Discussion in 'Project Logs' started by MAG, 14 Jul 2009.
  1. MAG
    MAG like Rocklander? => Thx for vote
    13 Jul 2009
    Hi together,
    here comes another "storybook".
    I begin with the project last year before the german championship.
    Because an error right from the planning I don’t let the jury rate the CON.
    Therefore I have another Chance this year.
    The material: Granite, aluminium and a lot of water in front of the monitor.
    For your Information first the assembling until today.
  2. thechoozen
    thechoozen Minimodder
    9 May 2006
    der MAG :D na das freut mich ja das du auch hier bist :thumb:
    Super das du das Auge noch fertig machst!! wird bestimmt super aussehen!!!
  3. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    erm....
    +1 what he said :jawdrop:
  4. MAG
    13 Jul 2009
    Und mich erst.
    Das hoffe ich doch.
    Now I start with the rear plate. I use the film to mark the cutting line.
    Before the sawing must the drill work a little bit.
    Just like planned.
    For the Power supply cutout I use a part from a old Case
    After drilling the holes it be a perfect guidance
    Just a little more straighten is needed for a perfect look.
    Not only a old case can be used. Also a broken Power supply is helpful.
    The TFC Triebwerk will be mountet direct. For this reason I cutt 4 M4 threads.
    To get a claen angle, I use the bolt-on "template" und the
    DREMEL-Schleifbänder.
    Done.
    A first preview
    ... to be continued
  5. honyin
    honyin What's a Dremel?
    8 Mar 2009
    cool mod love the blue between the granite.:rock:
  6. luis_pedro_Sato
    luis_pedro_Sato Minimodder
    29 Nov 2004
    the control buttons look great
  7. dreamreality
    dreamreality What's a Dremel?
    4 Mar 2003
    Looking good! Good luck with this. Can't wait to see the finished product.
  8. MAG
    13 Jul 2009
    Obrigado :thumb:
    Weiter gehts...
    To connect the fan internally it is necessary to break through this wall.
    A label helps to get a clear view.
    I dont want a hole for the whole connector.
    Just a push on the little hooks and the thing is done.
    How do you like it?
    After the assembling with some heat shrinkable tubing.
    Self-explanatory
    This holes are for the ...
    ... electrical power supply for the other "TFC Triebwerke"
    The Switch change between 5 & 12 Volt.
    The inner view
    Goodnight!
  9. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    very nice! I really like the granite and blue plexi and the control switches. Can you explain/show how they are connected?
    I don't understand the extra fan length in the back... but I'm sure more pics will explain... :D
    subbed
  10. MAG
    13 Jul 2009
    Of course I can show you how they are connected:
    I take a USB Gamepad...
    Some micro-pushbuttons and a old IDE kable. I like to use old parts. :D
    The result:
    Sorry, I dont have pictures from the mounting. Maybe this can help. It was one of the first sketch a show the mode of operation.
    The final connection: Just plug in the USB plug in the back. :D
    Here you'll find the Software PadControl at SPACEFLAKES. KLICK HERE
    I dont understand your question: "...the extra fan length in the back..."!
    What du you mean? I yust mount a "Case-Fan".
    Surely it is not a simpe Fan. It`s a "Triebwerk" from TFC (The Feser Company)
    ModMinded likes this.
  11. ModMinded
    26 Aug 2008
    Sweet! I like to reuse old parts as well! +rep for this and the software link
    by extra fan length, I was thinking that you have an additional fan on the back. It's a pretty thick fan. I was thinking it looks odd sticking out the back, is all.
  12. MAG
    13 Jul 2009
    If I find the place inside I will mount him there. :thumb:
    UPDATE:
    No real progress. Just a little motivation:
    At this point: Thanks to MSI
  13. MAG
    13 Jul 2009
    The flange will last long. :D
    I use the insulation from this old cable to protect my illumination wires.
    Complete.
    Later more.
  14. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    very cool i look forward to seeing more.
  15. ModMinded
    26 Aug 2008
    I want to see more later too! Those are sweet sockets for your lighting and controls!
  16. MAG
    13 Jul 2009
    Not mutch today.
    Just some labeling tests.
  17. DonT-FeaR
    23 Jul 2008
    looks cool :p
  18. MAG
    13 Jul 2009
    Today I start with the Radiator:
    Here again the TFC Triebwerke.
    For the optical part I mount some TFC Shrouds.
    With the Triebwerk and the shroud comes a lot of accessories...
    but for my combination I need some longer screws.
    A M3 thread rod and a cut-off wheel are self-explanatory
    A grinding disk for the DREMEL are perfect to cleen the cut.
    Done.
    The LED Module all have a 4-pin power plug. I am sure that is a good idea. But for "Cold Eye" I need a special thing.
    Cut to the right length. The rest is best-known.
    Now I have two plugs. One for the Fans and one for the LED.
    Here the back.
    Final result:
    later more...
  19. ringo
    ringo What's a Dremel?
    14 Jun 2008
    What did you forgot last year while your planning this con? From the Tv report I know that you had some trouble with the water inside the big eye. Do you have to make some parts new?
    I find your project interesting, I hope to see more than in the short film on Pro7 last year.
  20. MAG
    13 Jul 2009
    Last year I planed to glue the window in place with some silicone. Bad mistake!
    This jear I use a welded flange to bolt the window on th eye
    UPDATE:
    The front panel
    The connection circuit board for the ligths
