Electronics Cold Heat Soldering Irons?
Discussion in 'Modding' started by Springs, 28 Jan 2005.
  1. Springs
    Springs Boing boing
    29 Aug 2004
    Does anyone no where i can get a cold heat soldering Irons in the UK... ive tried looking through google but there was nothing except standard irons..
    they look really good and would be ideal for me so i can do some soldering inside the house...
  2. btk100
    btk100 What's a Dremel?
    13 Aug 2004
    I don't know about UK, but here in Canada they are nowhere to be found....I was looking for one before christmass but could not find one.
  3. Satyric_saint
    Satyric_saint What's a Dremel?
    4 Aug 2004
  4. Springs
    Springs Boing boing
    29 Aug 2004
    nope none on ebay for the UK..
  5. star882
    star882 What's a Dremel?
    19 Mar 2003
    I have owned a Cold Heat soldering iron, and it's great except that the ceramic tip wears out too fast and replacements are hard to find.
    I just got a cheap 100w soldering gun from radio shack, and it works great (for small joints, pulse the power so it doesn't overheat).
  6. Altron
    Altron Minimodder
    12 Dec 2002
    I used my friends Cold Heat iron a little. Not worth it, IMHO. It was difficult to get the two electrodes on the tip to heat up. I was trying to solder some 16ga solid copper and it wasn't giving me enough heat for it, because the stupid thing would only be hot for a few seconds at the time. I push harder trying to get it to heat up, end up splitting the $10 tip.
  7. Kerri Ann
    Kerri Ann What's a Dremel?
    12 Oct 2004
    i agree- they totally suck. it took me all of a week for the tip to become totally useless, and i still haven't found a replacement tip.
    i bought a weller soldering pencil for almost half as much, and it's lasted me a month and a half longer so far....
  8. nick01
    nick01 What's a Dremel?
    6 Nov 2004
  9. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    IMHO, there not worth it. the tips break really easily and they dont cool down as fast as they say. I have one and still prefer my generic soldering iron. again, stick to the standard iron.
  10. frag_daddy_2007
    frag_daddy_2007 What's a Dremel?
    19 Sep 2004
    you can get replacement tips at thinkgeek.com i got one today at ratshack and the tip was broke when i opened it, i found out later it was returned b/c it broke so quick
  11. kobaj
    kobaj Banned
    4 Jul 2004
    I was wondering when people would bring this up, but I think it isnt worth it.
    1. How are you soposed to 'tin' the soddering iron.
    2. Hold on let me think of something.
  12. star882
    19 Mar 2003
    You don't tin it. It's just some oddity with ceramic based soldering irons.
  13. Deflater Mouse
    Deflater Mouse What's a Dremel?
    2 Jan 2003
    The best thing about the cold heat iron is that it is cordless. It's great not having to run extension cords out to the car or wherever just to solder one joint. I wouldn't use it for populating circuit boards and the like, but it is really handy for when you only need to solder one or two things and don't want to babysit an iron while it heats up and cools down.
  14. Altron
    Altron Minimodder
    12 Dec 2002
    I think a lot of using them is not having any experience with normal ones. My friend had no problem using his, but I had always used a normal one, so I was not used to the technique.
    I also don't feel that it gives good joints. I've always been told by the EEs I know to thoroughly heat the joint, using the wire to melt the solder, not the iron to melt it. With the cold heat, it's difficult to get it to heat up the metal, all it seems to do is quickly melt the solder.
  15. NoCoolOnesLeft
    NoCoolOnesLeft What's a Dremel?
    31 Dec 2004
    You guys who have had troubles probably used normal solder. You need to buy ultra thin electronics solder. I have one and it works fine with the thinner solder. But i could see the tip wearing out, but it seems easily replaceable.
  16. star882
    19 Mar 2003
    Yup, the Cold Heat is great for field repairs. It probably wasn't meant for frequent use.
    Then the solder heats the joint, and a good connection is made.
    And does anyone know how the Cold Heat works in the first place? It seems to have some sort of sensor in the tip that powers on the heating element only when necessary.
    Just to let you know, I think that my $15 Radioshack soldering gun is the best one I've used so far. Replacement tips are easily available and it heats up and cools down quite fast. (And yes, it will work for small connections if you pulse the trigger so it doesn't overheat. (Or use a light dimmer/variac to reduce the power if you find it bothersome to pulse the trigger.))
  17. Altron
    Altron Minimodder
    12 Dec 2002
    There are two electrodes in the tip. It heats up when they are shorted.
  18. chalk_mark
    chalk_mark What's a Dremel?
    8 Aug 2004
    If all you want is portability, why not get something like a Portasol, gas powered catalytic iron. Even Weller makers one, they have heatshrink hot air tips, knives, and a range of tip sizes. they are about the size of a big permanant marker.
    http://www.portasol.com/intro_index.htm
    http://www.cooperhandtools.com/europe/sales_literature/documents/WellerPyropen_GB.pdf
    Cold heat is just a spiff name for resistance soldering, and from what I have seen, this products has not been made very well. Resistance soldering is quite common in industry, from large terminal soldering to tiny SMT tweezers. Of course, they use well designed, adjustable equipment.
  19. frag_daddy_2007
    19 Sep 2004
    i have a butane iron, it just takes too long to cool. i do like th cold heat for small repairs though, exept for the fact that when i was using .22 ga solder it got too hot and literally vaporized the flux out of it. other than that its an ok tool worth the money in my opinion
  20. kbn
    kbn What's a Dremel?
    17 Mar 2004
    they dont take that long..
    Id recommend the solderpro50 over the other one. From the specs, I think its better. £10 at maplin or £12 at rapidelectronics. Maplin sells spare tips (RE doesnt but has the kit with tips for £20)
    Anyway.. nothing to stop you dipping the tip in a glass of water... that would cool it instantly.. (watch out for steam!). Only dip the end in, as itll be easyer to dry.. wouldnt want the catalyist to rust.. (whatever its made off...)
