Modding Cold Heat Soldering Tool -- Does It Work?
Discussion in 'Modding' started by BoCoMoFo, 29 Jun 2004.
  1. BoCoMoFo
    BoCoMoFo What's a Dremel?
    30 Sep 2002
    If you don't know what I'm talking about, you can see it here: http://www.thinkgeek.com/gadgets/tools/69d3/
    If you do know what it is and have used it, I'd like to know if it actually solders as well as a standard soldering tool.
    Anyone? Anyone? :dremel:
  2. apoogod
    apoogod trix arent just for kids
    19 Jun 2002
    I just saw a commercial for one like that, i dont think it was the same but same concept. I to would like to know what people think of them
  3. Mecha_Mindslayer
    Mecha_Mindslayer Banned
    23 May 2004
    If these things work im going to defo buy one. Would save my fingers :eek:
  4. JoyRider
    JoyRider What's a Dremel?
    7 Jun 2004
    I'd buy one........It'll save a lot of energy, no power cable or anything, just 4 simple rechargeble batteries. It cools down instantly so you won't burn your hands on it if you've laid it down and touch it without notice.And it's cheap.... :D (for a soldering iron)
  5. PsychoI3oy
    PsychoI3oy Minimodder
    13 Apr 2004
    disclamer: don't own one, never used one, don't know anyone that has...
    the biggest problem I see with this tool (and any others similar to it) is that in order for it to heat up, the tip has to have both sides of the split in contact with metal to create an electrical current. This is a problem when working on very small things where there's simply not enough room to touch both halves of the tip, and also when working on electronics that'd be sensitive to random voltages passing through them.
    just my $.02US
