Scratch Build – Complete Cold Winter V.3 by C4B12 | 14-02-23 (completed)
Discussion in 'Project Logs' started by C4B12, 15 Nov 2012.
  1. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    Loving it! such a tidy build! keep up the good work :D
  2. C4B12
    C4B12 Minimalistic PC's
    6 Oct 2011
    Thank you! :)
    The loop is filled with Mayhems, its leaktested and the computer boots up! This project is now finished. I took some pictures of the result, the final pictures will be taken tomorrow though, but here are some sneakpeaks.
    What do you think?
    With kind regards
    Johan Nyman
    Minimalistic PC's
  3. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Very stylish and clean, nice work Johan!
  4. C4B12
    6 Oct 2011
    Thanks Bill! :)
  5. C4B12
    6 Oct 2011
    Final pictures!
    Hello everyone!
    So I finally finished Cold Winter, the third version. I went back and checked when I started the first project log for this case, 2011-01-04, a while ago. However, this mod has meant a lot to me, this was the second serious project I made and the first one I was really satisfied with. Since then I made a second version and then started planning a third version that I promised myself was going to be the last, and here it is!
    The sad part is the scratches on the acrylic, this was made when I built this case at my school, someone there thought it was funny to start etching stuff on it, the same happened at Dreamhack. So sad, I tried as good as possible to polish it but not with a really good result. The good part is that isnt really easy to see if you dont put a light right on the scratches.
    I want to say thank you for all the nice comments and feedback of Cold Winter and I also want to give a big shoutout to the sponsors for helping me with the hardware!
    EKWB! Thank you for helping me.
    Be Quiet sponsored me with a Shadow Rock 2.
    Gigabyte sponsored me with a GA-F2A88XN-WIFI.
    MNPCTech sponsored me with this fan grill to have in the front, should look awesome!
    Clear Acrylic 120mm Overkill "Nautilus" PC Fan Grill from Mnpctech.com
    Well do you want to see the final pictures? Here you go! :)
    Ill be back here with more updates on other projects. Until then, I would be happy if you would like to check out my facebook-page where I post all my projects, updates and giveaways. Check it out and like it. :)
    Thank you everyone!
    With kind regards
    Johan Nyman
    Minimalistic PC's
  6. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Great build mate :thumb:. How are temps with a single rad ?
  7. C4B12
    6 Oct 2011
    Thank you! Well when only cooling the CPU it is no problem, the rad is pretty thick too. :)
