Build Advice College build
Discussion in 'Hardware' started by AQNFX, 21 Apr 2009.
  1. AQNFX
    AQNFX Twist The Grip, Let It Rip!
    17 Jul 2008
    My girlfriend needs a computer for college. She has come to me asking for a computer. I am having a hard time choosing for her because I just want to build a gaming machine (she doesn't play games she's into makeup and fasion :nono:). So she likes to watch movies, surf the web, and listen to lots of music. I want to build something that will meet her needs and last the duration of college. She would also like it to be as cheap as possible. I would like it to have great reliability and quality.
    Option 1.
    Asus P5Q-EM -------|||------ Maybe the Asus Maximus II Gene if its under $140
    intel Q8200
    OCZ 4GB DDR2 800
    WD 250HDD - will add more when its needed.
    Antec 180p mini case
    Option 2.
    Asus M4A78-EM
    AMD AMD Phenom II X4 920
    OCZ 4GB DDR2 800
    WD 250
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Get her a laptop.
  3. AQNFX
    17 Jul 2008
    she doesnt want a laptop
  4. oasked
    24 Aug 2005
    #2 then. Both systems are still overkill though.
  5. alastor
    alastor Minimodder
    6 Sep 2004
    If there's no gaming or heavy duty processing required then you'd be better off saving the cash and going dual core, at least on the Intel setup anyway.
  6. AQNFX
    17 Jul 2008
    how would you guys build it then?
  7. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Swap the CPU for an E5200 and the HDD for a 500GB. :)
  8. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    #2
    Both are overpowered, maybe drop the RAM to 2Gb and the CPU to the E5200 and then get like mm ve said, a 500Gb HDD. Does the onboard video chip allow for HD? It may be worth using the money saved to get a cheap card like the 8400GS?
  9. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Go for a Dell...
    with cheap computers it makes a lot of sense.
  10. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    If we all followed this logic, this forum would not exist. It's not just about the end result, it's everything that leads up to it that really makes it your (or her in this case) computer.
    /off topic
    I agree with the HDD change. As cheap as storage is these days, there's no reason not to.
  11. Guest-16
    Guest-16 Guest
    Dell, cause she'll only blame you if it goes wrong.
    Been there, did that, didn't like playing tech support.
  12. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Asus M3N78-VM
    AMD Athlon 64 X2 5200
    Corsair XMS2 4GB (2x2GB) DDR2 PC2-6400C5
    WD Caviar Green 500GB
    Antec Mini-P180 White
    My reasonings, the motherboard has on-board Nvidia 8200 graphics, but also has a PCI-E slot for a more powerful card if blue-ray decoding is required later on.
    CPU, well its a dual core and its cheap dirt cheap in fact and for basic surfing and music playback, DVD's its perfect.
    Memory 4GB is becoming the normal amount, vista is a pig but Win7 is on its way. Personally i would hold out for Win7 skipping Vista. Memory is ideal for multiple tabs in firefox and huge playlists in winamp.
    HDD, the green drive might save some cash on the old elec bills, so every little helps in the long run. Speed of the drive isn't really important for her.
    Antec Mini-P180 isn't as small as you might think, its the same size as my Lian li V1000b sat next to me, which was a shock to me at first. The mini really is a brick!
    I suggest it in white, as it will be 'cool' and more than likely match her ipod. And possible result in envy from her new friends who all were bought Dells by there parents.
    If you really care about her, forget the performance spec of the machine, and get her a quality screen, keyboard and mouse. There isn't anything worse than a bad combination of screen, keyboard and mouse, hands ache and eyes ache. Set the screen up for her and show her how to adjust it, so she dose become blind whilst twittering or facebooking in a dark room due to an over bright screen.
  13. alastor
    alastor Minimodder
    6 Sep 2004
    Agreed, my previous had her entire family using me for everything even remotely computer related.
    If you don't want a Dell/HP/Acer/whatever, then find an nvidia board with some decent enough onboard graphics and put an E5200 in it, 2/3/4GB of branded but cheap RAM, 400W (if that) branded PSU and however big a HDD you can afford with what's left.
  14. wgy
    wgy What's a Dremel?
    28 Jul 2008
    i recently gave an old pc to a friend,
    amd 3700+
    2gigs ram
    250gb HDD
    nvidia 5**FX series 256mb graphics...
    400watt psu
    he uses photoshop alot.. (illustration student)
    games, (it can run WoW and HL2 no problems :blush:)
    and has a butt load of music, as well as record his own + edits
    obviously, it wasnt amazingly fast. but it was never too slow, and was capable of anything he needed doing. so from this, i would imagine your quad core, asus maximus gene motherboards and 4 gigs of ram is overkill.
    and as stated above, would go for a dell :D orrrr if you want to build it yourself, go for a e5200, motherboard with onbord sound and graphics:
    like this? http://www.scan.co.uk/Products/Gigabyte-GA-EG31MF-S2L-iG31-Express-S775-PCI-E-(x16)-DDR2-667-800-SATA-II-SATA-RAID-Micro-ATX
    500gb HD, and a cheap psu, like 300 watts or something.
  15. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    when you say fashion, what does that mean? are there fashion apps? is she photoshopping alot?
  16. trig
    trig god's little mistake
    10 Aug 2006
    yup yup...unless you get paid for the tech support :eyebrow: you know what i'm sayin :baby:
  17. Burnout21
    9 Sep 2005
    I make my partner follow a simple rule, dont download or change anything with out my permission!
    I play tech support for her, but we live together. i set up the machine or laptop so it dose everything she requires, and then i think ahead a little of what might be needed.
    I then make sure its updating when it needs to.
    I pretty much install the most stable drivers availble at the time and leave it at that. She's pretty good at not fluffing around in settings.
    Only thing i got a little miffed off about was on an old laptop her parents gave her she told me she was going to uninstall some stuff, and i found she just deleted the shortcuts from the start programmes tree, bless first time i guess.
  18. AQNFX
    17 Jul 2008
    She buys makeup and spends her money on high end fashion like Gucci, lui vuitton, and DG.
  19. AQNFX
    17 Jul 2008
    I wont be getting paid with cash per say....... but ill be getting something.... :naughty: :rock:
  20. trig
    10 Aug 2006
    when it's all said and done, that's all we really need. air and water are sooo overrated.
