Modding Colored 40 mm fans?
Discussion in 'Modding' started by GigantoR, 21 Jul 2004.
  1. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    Does anybody know of anywhere that sells clear or uv green 40 mm fans?
    Workin on a project and they would look great in my hdd rack and in one other spot that is too small for any other fan.
  2. stoned penguin
    stoned penguin What's a Dremel?
    23 Mar 2004
    just paint them with UV green spraypaint :thumb:
  3. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Xoxide sells clear 40mm fans with a blue LED embedded in the middle. You can buy them and take the Blue LED out and that would satisfy what you need.
    You could also go to Soyo's E-Store and purchase the 40mm fans that are clear that they use on their motherboards. The one I know of that uses the clear 40mm fan is the "SY-KT400" motherboard. *I think you can do this with no trouble*
  4. GigantoR
    21 Jul 2004
    Thanks guys, I think I'll stick with black and the other spot I was looking at for a fan probably won't fit one now that I checked it again.
  5. CREDO
    CREDO What's a Dremel?
    18 Jul 2004
    Sweet.
    I have been looking for a 40mm blue led fan for ages, i want to replace the fan in the aerogate 2.
    The problem is I live in australia and Xoxide only ship to US and Canada.
