I could do with some of this for an upcoming show (just the dyes, not the actual coolant), any hint as to how much a dye bomb (as it were) would be?
Hi there bigsharn Send the info of the show via PM and details of what you are after and Ill sort you some of free of charge ... Hows that sound. Oh and the price for each 1.8 ml Vial will be £2.99 + P&P, Then there is 5ml bottles and 10 ml bottles as well. Just for your Ref. Im ready with the shop to go live the only thing i haven't got yet is Pro taken Pictures which is what is holding me back with the shop.
If any one is doing a project and is interested in getting hold of some before the shop goes live then contact me and we can talk about your requirements. I dont mind helping people out.
The shop is now live. http://www.wcdyes.com Only the dyes and powders are up for sale atm. more will be added over next few days. Have fun ... If you have any problems let me know .
Looks pretty good, but how is it's long term reliability for 24/7 high heat output (ie OCed i7 920)? How is it's affect of Acrylic?Delrin?Tygon? (In the long term). Because if I use this I don't want this to happen: http://www.xtremesystems.org/forums/showthread.php?t=226632 in the long run. Go to pg 15-16 to see it happen to other blocks. I am looking at using this (esp. a red color) for an upcoming build in March - July. I and many others (esp. at OC Forums) have been anti-additive because of this, and are recommending going with colored/UV tubing instead to get the colors (and Kill Coils or PT Nuke to kill the nasties + distilled water). So as you can understand, I am a bit hesitant to try this. edit: See my next post
read through the whole trad at XS -> http://www.xtremesystems.org/forums/showthread.php?t=230290 been very open and honist with ppl on there . as you can see reading through we have tested most thing but its impossable to test every thing. as for what you have said that was done with a pre mix not just a dye. That happens when the anti corrisive materl brakes down. (in the tread you pointed out)
Ok, just spent like 40 minutes reading through the XS thread and it looks solid! Anyways, just a clarification: I would still need to use KillCoils/PT Nuke for the loop right with the dye? Or is that not needed? PS: I will let others know about this over at OCF,etc. . edit: One more thing: This is patented/copyrighted (or some sort of IP protection) right?
No there is no patent or any thing along them lines. You will need a kill coil or pt nuke with it yup. i suggest a kill coil my self and then there is less chems going into the system. I know that if you use to much anti mixed metal stuff this does cause build up as even i have seen it happen.
Thiese pics were taken from a reviewer in poland and then some more updates from me -> UV Black with black back ground UV Black with Black back ground Under UV Candy Red Left, Blood Red right. Under black back ground Candy red Left, Blood Red right. Under Red back Ground UV Yellow / green left, UV Yellow / Green 50/50 middle, Uv Pink Under black Back ground UV Light on. UV Yellow / green left, UV Yellow / Green 50/50 middle, Uv Pink Under red Back ground UV Light on. UV Clear Blue 1,2,3 Left to right. White back ground no UV light UV Clear Blue 1,2,3 Left to right. White back ground UV light on Uv Clear Blue 1,2,3 Left to right. Black back ground UV light on last pic. All the dyes can be mixed to create you very own colours as shown up above e.g the marien blue looks realy good . if you intrested in getting so dyes for you project just head over to my shop at wcdyes.com and send me a message showing your work logs and youll get some nice free be's from me ...
Hi there check your Pm's OMG £19.00 for a premix blood red ... thats bloody shocking check out my premix when it comes out ....
Sneek Peak -8.9 at -10c it start to christalize The sticker froze before the liquid lol. Ill let the pics do the talking any way. 10 min later passed through filters to show and problems with brake down after being frozen. No point boiling it becuase this will never show brake down of any liquid. This is now being packed up and sent out to testers...... so ill see what the come back is when they are ready ..
Pre mix under test now 6 version in total Clear / UV Pink / UV dark Blue / UV Clear Blue / candy red / Yellow , green Mayhems Dyes X1 - premix for water cooling system's and computers is echo freindly and non toxic out of the bottle. You can add any of Mayhems dyes to produce some of the most vibrent colours for a water cooling system to date. Features of Mayhems Dyes X1 * Can be used with any of Mayhems Dyes * No need for adatives such as Biocide or Corrosion Inhibitors * Proven to ASTM D3306 and BS6580 Standards * Non-toxic, environmentally friendly * Protection against copper, brass, steel, nickel, aluminium * Will not wear down sealent or glues on acrylics and plastics * Better heat transfer and flow characteristics than propylene glycol for systems operating between + 50°C to - 10°C * Freezing point of -8°C to -10°C * 2 Year Shelf life And will be cheap for buyers and resellers ...
