Electronics Coloured PCBs? :o
Discussion in 'Modding' started by Duste, 22 Dec 2006.
  1. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    So, these big companies can make these fancy coloured PCBs (black, blue, red, white, etc...), so is there a way for us little people to make them? :p
  2. eutronix
    eutronix What's a Dremel?
    28 Nov 2005
    Sure there is. What you want is to specify soldermask color. You just order a one of those colors with what most board houses refer to as a production order. They usually allow you to place small quatity orders, but you lose out on the the savings of a large order because you pay the same setup fees regardless. Most board houses also charge an additional nominal fee for soldermask colors other than green. Expect to pay in the neighborhood of $300 to $500 US for most orders.
    Hope this helps,
    Stu
  3. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    You can paint your the PCBs before soldering the components on if you are utilizing through the hole. Just don't paint the side where you will apply the solder to.
  4. JCG
    JCG What's a Dremel?
    1 Dec 2005
    sorry if this is seen as spam but:
    I have very good experience with this Ebay shop : link
    Plus he has a dutch bank account, so no international transfer fee for me :D
    The black pcbs are beautyful, especially when the pvb stays visible.
  5. Duste
    1 Oct 2006
    I want to make the actual PCB myself, I was just wondering if I could get different colours myself, but thanks anyway, good link! :D Now I know that it's solder mask that I'm looking for. ;)
  6. eutronix
    28 Nov 2005
  7. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    easiest way is to first etch (ofcourse!) and drill the pcb.
    Then get some circular stickers in the right size. Put stckers on all the soldering pads, and paint the whole thing.
    When paint is dry just peel of the stickers.
    For a nice effect on the chopper side, use transparent paint (window-tint?)
  8. Duste
    1 Oct 2006
    Yeah, that's what I was thinking as well. I wouldn't need to worry about the copper lines, would I? It'd still be able to conduct underneath the paint, yes?
  9. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    painting the copper wont change its atomic structure :D
    so yea. it will still conduct :thumb:
  10. Duste
    1 Oct 2006
    Lol, I know that but..yeah, okay. :p
    I should get nice indents from the copper underneath the paint anyway, right?
  11. FuzzyOne
    FuzzyOne
    19 Sep 2002
  12. Explicit
    Explicit What's a Dremel?
    23 Dec 2002
    There's methane in the atmosphere already... And I'm sure farting isn't going to bring on global warming any quicker.
  13. Emon
    Emon What's a Dremel?
    14 Jun 2004
    I concur with these. So often I seem people puzzled at how to paint, lacquer, etc., their boards without ruining the pads. The answer is just that simple. :wallbash:
  14. Smilodon
    25 Mar 2003
    There is one problem with this, though. If the pads and traces are pretty big, you might find the paint melting in the area close to the pad during soldering.
    Normally it shouldnæt be a big problem, though.
    and yes, the chopper will still conduct. In fact, the paint will protect the chopper from oxidizing.
  15. Duste
    1 Oct 2006
    So it's actually a bonus to take the time to paint it, as well as for the looks?
  16. Smilodon
    25 Mar 2003
    correct. Anti corrotion is one of the reasons that professional PCBs is painted (or gold/tin plated.
  17. cpemma
    cpemma Ecky thump
    27 Nov 2001
    A better reason is that the "paint" used for covering the tracks is a solder-resist, so in wave soldering only the unpainted pads (and components mounted on them) get a solder coating. Saves solder and the risk of solder-bridging of close tracks.
    'Conformal coatings' for corrosion and weather protection are usually transparent and sprayed over everything, including the components.
  18. Duste
    1 Oct 2006
    Cheers for the information guys. ;)
  19. chief11
    chief11 What's a Dremel?
    13 Dec 2006
    You could use automotive engine paint, shouldn't burn easily when you solder.
  20. Smilodon
    25 Mar 2003
    I don't think you'll find it as transparent (transparent color) paint, though.
    Just remember jo put it in the oven first. Often these paints doesn't cure before they are exposed to heat..
