Electronics COM PORT WINAMP CONTROL - volume controllers
Discussion in 'Modding' started by Lemonize, 14 Jan 2007.
  1. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    I think in this case the location of the control has some merit... if this was feeding a remote amp, it's probably not the best scenario to have the pot at the end of a long run of line signal cable...
    But yes, I agree with you, that's why I mentioned it ;)
  2. Lemonize
    Lemonize What's a Dremel?
    14 Jan 2007
    i just thought, that i even dont need to change the knob - i will just put another one on it and that is all. it could be easier, imho. cuz every time i see all these electronic schemes i have headache :duh:
    i did already, yesterday. now waiting for the reply. could be good also to find some retailer in europe... on netherlands page i dont understand anything, all in holland lang.. will try uk etc.
  3. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    I don't say that analogue volume controls are worse then digital (software) alterations to the signal... but simply putting a dimmer-pot on a line-level signal is ugly... bad... evil... yuck :p
    anyways, about the topic, the way to use that rotary-encoder is explained in the file agent420 linked to... so that's one problem solved... what was the other problem again? :hip:
    EDIT: I see, electronics isn't your thing? :p nobody nearby you able to build a circuit for you from that schematic? It's a very good one... all you need is some simple cmos parts...
  4. Lemonize
    14 Jan 2007
    electronic is really not my thing. i can build some simple things, but this scheme is hard for me. i will ask people around, also.. but if Powermate is able to control winamp in background, i will buy and modify it. up to know it is easier for me.
  5. DonCorleone76
    DonCorleone76 Modmaster deluxe
    1 Feb 2005
    It will control volume also when winamp is in the background, because it regulates the main volume of your windows, so therefore also winamp, it's very modable :dremel: , and it looks cool, the mainknob is easily removable from the base, so i think your goals will be met the most simple way when you'll use this device. links:
    http://www.thinkgeek.com/computing/accessories/5ca2/
    http://www.amazon.com/Griffin-Technology-PowerMate-Multimedia-Controller/dp/B00006BINO
    http://www.gizmodo.com/gadgets/home...-on-ipod-dock-pats-selves-on-backs-226644.php
    best of luck. Theo.
  6. Lemonize
    14 Jan 2007
    thanx, Theo. what do you by "the main windows volume"? volume taskbar.. ?
    if that, then it is even more easier to me take off the volume regulator from speakers, for example, connect it direct to sound card output and then make my mod. :dremel:
    i need exactly winamp. let's wait for the reply from griffin, i hope they will reply in nearest days. :rolleyes:
  7. Lemonize
    14 Jan 2007
    not so good as I thought :blah:
    reply from griffin: "Actually it will only control the volume of the computer not WINAMP unless you are in WINAMP itself."
    then i see, that there is no sense to me to buy powermate. i saw some articles over the internet, how to make external system volume controller.
    i will publish them here also, for you just to have a look and may be give some advice. :dremel:
    found one - in connection with game port:
    but i can not understand, how to unite (knit together?) it. where is the 3rd resistor leg.. ? etc.
    can you advice smth? thx :dremel: :)
  8. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    The thrid leg isnt attached to anything iirc
  9. DonCorleone76
    1 Feb 2005
    The picture is quite self explanatory, just a matter of soldering the numbers in the diagram to the same numbers on a 15p d-sub connector for a gameport.
    Can you give me the link of where you found this picture, because i've tried to find it, but google let me down.
    Thanx in advance.
  10. agent420
    18 Apr 2006
    Perhaps I have not ingested enough coffee, but that led wiring scheme looks all wrong...
    And is that some kind of encoder setup, or simply dual pole switches with led indicators?
    And, you still have a game port? Wow.
  11. Lemonize
    14 Jan 2007
    this scheme is named: mixer game port control.
    you connect 4 resistors to game port, install 2-axes joystick to windows, configure all with software, and you can regulate master, cd, wave and midi - externally.
    it does not work under xp, i as found.
    now i am just putting the resistor between line-out and speakers..
    i will show the scheme a bit later
  12. Lemonize
    14 Jan 2007
    What is what on the scheme - potentiometer
    guys, how do i "read" this resistor:
    all the contacts are in one line, i can not understand what is what on the scheme... :wallbash:
  13. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    You need to find the datasheet for that part. It'll tell you in there what's what.
  14. Lemonize
    14 Jan 2007
    i would be happy.. but i dont know even the name of it.
  15. agent420
    18 Apr 2006
    I am hoping you have that part already and are not just asking about some random part by providing a photo of it here with no other clue as to where you located it, what part #, etc., because that would be pretty silly. :eyebrow:
    Use a multimeter and measure the resistance across various legs as you turn the knob. If you do not have a multimeter, go out and buy one, you can get a cheap one for only a couple of $.
    If I had to simply guess, I'd say that it is double ganged with the left 3 pins wired to one pot and the right 3 wired to the other, and pins 2 and 5 are the wipers.
    edit -
    Reading your post again, what scheme are you referring to?
  16. Lemonize
    14 Jan 2007
    yes, i have scheme.
    here it is:
    when i had double-resistor with 2 "levels" that was not a problem :wallbash:
  17. RickDawson
    RickDawson Minimodder
    29 Mar 2006
    has anyone managed to get anything working?
