Scratch Build – In Progress Combine Ceiling Turret
Discussion in 'Project Logs' started by Mindphaser, 11 Apr 2012.
  1. Mindphaser
    Mindphaser What's a Dremel?
    27 Jul 2010
    Hi everyone.
    I am an entry-level modder from Ukraine.
    This is my second modding project, the first one http://forum.coolermaster.com/viewtopic.php?f=49&t=14808.
    I have no sponsors, so project budget is limited and hardware is not state-of-the-art.
    Here is the hardware list
    CASE: full custom
    PSU: Flex-ATX Seasonic SS-250SU
    MB: Gigabyte H55N-USB3
    CPU: Intel i3-550
    CPU cooler: Intel box (fan replaced)
    MEM: Hynix DDR3 2x2G 1333MHz CL9
    GPU: Asus HD7750 512Mb GDDR5
    HDD: SATA 160Gb Samsung SpinPoint F1 8Mb
    DVD: DVD-RW SATA Sony Nec Optiarc AD-7690H (slim slot-in).
    Concept.
    If you ever play Half Life 2, you have to remember Alliance turrets, including Combine Ceiling Turret:
    So I’ve plane to make the case not in the style of the game but highest possible close to original source.
    Also inspiration objects photos:
    Layout
    2D layout:
    3D layout:
    Here are the initial set of materials
    So, the frame made from aluminum angle bars, side panels - glass-fibre plastic, and the rest during the process.
    Getting started.
    Install the CPU cooler – its height is not very pleased. Have to replace the fan by low-profile one.
    To initiate the process make a power supply unit angular mounts:
    Adjust the attachment holes and fan cut-out:
    Time to handle a framework. The problem is that the case almost have no right angles, all surfaces are sloped - will have some fun.
  2. jhanlon303
    7 Sep 2006
    Interesting.
    I watch.
    john
  3. dirky90
    dirky90 Minimodder
    19 Mar 2012
    haha, this is going to be so good!! amazing concept drawings!! and you cant beat half life!!
    if you are struggling for space you could drop to a 2.5??
    rob
  4. Guest-23315
    Guest-23315 Guest
    Very much liking the idea of this.
    :thumb:
  5. Mindphaser
    27 Jul 2010
    It's no sense to replace the 3'5" HDD to 2'5" one. In that place enough space in all dimensions. Anyway thanks for comment :thumb:
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Interesting :) your other project looked crazy, good crazy. :D
  7. Mindphaser
    27 Jul 2010
    Yeah, really? ;)
    I think that every techno geek should have a cyber monster like this :naughty:
  8. Mindphaser
    27 Jul 2010
    Let's continue.
    The pair of rear frame’s profiles:
    Manual bending:
    Angle revision:
    Forming the rear side of the frame:
    HDD mountings treatment:
    Mid frame profiles cutting:
    Trying on the motherboard:
    Rear panel cutouts:
    Have to make cutouts for memory modules too:
    Frame assembly.
  9. dirky90
    dirky90 Minimodder
    19 Mar 2012
    wow, it looks so good so far!! I cant wait to see how this turns out. keep up the good work!!
  10. Samrobmoe
    Samrobmoe What's a Dremel?
    7 Apr 2012
    This is looking truly EPIC, I literally cannot wait to see this finished in all it's combine-y glory
  11. Mindphaser
    27 Jul 2010
    dirky90, Samrobmoe Thanks guys, you will not be disappointed :naughty:
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    This is shaping up absolutely awesome mate, sweet bar work. :dremel::rock:
  13. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
  14. Mindphaser
    27 Jul 2010
    The frame is almost ready, can place the hardware.
    Installing PSU:
    PSU cable assembly:
    Here is the secret ingredient - furniture hinge.
    “What for?” you can ask.
    The fact that the lid will be a separate structure that is rotated forward relative to the frame.
    Lid close position:
    Lid open position:
    So, a furniture hinge serves as a pivot joint.
    A video card housing will slide back through the guide:
    The conclusion on the results of fitting the power supply - there is a problem with wires.
    In the sense of wires packing in a tight inner place.
    P.S.: I almost forgot to say - no machinery tools used, except screwdriver. All works done by hand tools.
    Waynio likes this.
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    A whole lot can be done with hacksaw & files & some random bits from a DIY shop :) very nice work mate. :rock:
    I would only get a manual drill if I wanted to do a blackout mod though, a mod without the aid of electricity, nice bragging rights come with that I think. :clap::D
    Edit: powerdrill :hehe: still nice though & repped earlier. :)
  16. Guest-16
    Guest-16 Guest
    Anyone else getting dead pics? :(
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    Don't know but I can see them.
  18. jhanlon303
    7 Sep 2006
    Pics work for me
    john
  19. Mindphaser
    27 Jul 2010
    The next assembly. Now the PSU fixed.
    Graphics card and cooling system added for the sake of completeness:
    Livio likes this.
  20. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    lol!
    cabinet hinges, aluminum, computer and modding!
    LOVE IT!
