It’s time to attend to frame mounting parts. The joint plate at first: Made from 1,5mm thickness steel: It attached to rear part of frame:
Combine Ceiling Turret : cantilever - update 18/04/12 Lets take a closer look at the mounting cantilever: It’s made from steel perforated plates and aluminum angles: Trapezium-shape part cut-off from box-shaped level tube by the actual size printed template (do you think it’s too big for mini-ITX case?): Vee-type part in closer view: The video output extension cords and power cord will be tracked inside. Something like this:
Plodder, Tech_Jakl Thanks for comments, but a complicated and interesting work waiting for me shortly Be tuned
Very impressive! The idea is just great, and the materials you take use of i genious Looking forward to seeing more of this, subbed!
That last update looked like "I went to the hardware store and grabbed some random stuff... this is what I came up with" I love it! Keep up the great progress Mindphaser
Combine Ceoling Turret: I/O panel cover - update 20/04/12 It is time to prepare a little bit of aluminum sawdust. Start to make a MB rear panel cover. The top canopy at first: Then side parts: Testing: Side parts will be removable, attached with screws.
