Scratch Build – In Progress Combine Ceiling Turret
Discussion in 'Project Logs' started by Mindphaser, 11 Apr 2012.
  1. Mindphaser
    Mindphaser What's a Dremel?
    27 Jul 2010
    Combine Ceiling Turret: video card output box - update 10/05/12
    Switch over to to a video cart output box, this part:
    The front of the box rounded shape, for it has used aluminum furniture leg diameter of 40mm:
    Dismantled, prepared for cutting:
    By the way, how to mark a longitudinal line of cut (in a sense parallel to each other and the axis of the cylinder)? Found the way - put angle:
    A little hacksaw work:
    That’s all for a while.
  2. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Coming together nicely!
  3. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: DVD-box - update 15/05/12
    Start the DVD-box assembly process:
  4. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    interesteing:D slimpel but Advanced
  5. bluc
    4 Apr 2012
    Coming together very nicely:rock:
  6. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    OOOOOOOOOHHHHHHHHH YYYYYYYYEEEEEEEAAAAAAAA
    Great looking mod, keep up the great work :thumb:
  7. Overminde
    Overminde What's a Dremel?
    15 Sep 2011
    Great build mate. nice skills
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice progress. :)
  9. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Still looking sweet! Nice progress
  10. Mindphaser
    27 Jul 2010
    fr0Zen, bluc, The_Beast, Overminde, Waynio, Mosquito
    Thanks for the comments... There is no time for work for a while, log to be continued through a few weeks
  11. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: CPU cooler mod - update 22/09/12
    For some reasons have to replace CPU cooler by the low-profile Cooler Master Gemini II M4:
    Despite the fact that is the lowest Cooler Master cooler, I have to modify it.
    First, remove the fan, and then gave it a trapezoidal shape:
    In rotate position heat pipes run into the capacitors and the cooler base not in contact to processor
    Need to raise the cooler on the heat sink:
    Tinkering heat sink and heat pipes, a second attempt
    To warm up the heat pipes cooler is placed in a container with boiling water on the gas stove
    Heat sink roasting
    Cooler assembled
    Modified CM Gemini II M4 tests on OCCT v.3.1.0:
    With stock fan - better then original!
    Passive –fail (even without load):
    With Titan TTC SC-04 blower
    That’s my choice:
  12. bluc
    4 Apr 2012
    Awesome to see you back have been hoping the project did not die :thumb:
  13. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: blower mod - update 16/10/12
    Titan’s blower need to be modified - have to reduce its length and cut through inlets for intake air.
    Disassembly and cutting:
    Going back. Reposition the motor stator:
    Approximate position in DVD-box:
    Air inlet:
    Livio likes this.
  14. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Great work. I can't wait to see it on the ceiling. ;)
    5 star for you.
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice work on the cooler Mindphaser. :dremel::clap:
  16. Cheapskate
    13 May 2007
    :thumb: Great work. If I had tried to modify that cooler, it would have ended badly.
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    ^ Trying to fix my direct heat pipe cooler did end up badly for me. :hehe:
  18. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: roof grating - update 18/10/12
    To make a roof grating use furniture lattice from this set:
    A flashlight purpose will explain later ;)
    Resizing:
    Grating attachments:
    Install grating on the side wall together with the exhaust turbine:
    The side walls painted inside at the same color as an aluminum frame:
  19. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: video card housing - update 30/10/12
    Keep assembling video card housing:
    ShinyAli likes this.
  20. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
    Only just seen this build, great work, it's my kind of build using anything and everything you can get your hands on and just making it work :rock: +rep
