Scratch Build – In Progress Combine Ceiling Turret
Discussion in 'Project Logs' started by Mindphaser, 11 Apr 2012.
  1. Mindphaser
    Mindphaser What's a Dremel?
    27 Jul 2010
    Combine Ceiling Turret: video card housing - update 02/11/12
    Lets make front part of video card housing:
    Use an aluminum box-shaped profile:
    One of these turbines will be installed inside:
    So I have to give it a breath of fresh air, mark the holes:
    Drilling holes
    Ream a holes
  2. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: video card housing - update 12/11/12
    Still making front part of video card housing:
    Use an aluminum darby:
    Hand made perforation:
    Top parts:
    Adhesive tape assembly:
    Front part:
    After a while:
    Cut away the needless edges and sanding:
    Final assembly:
    Waynio likes this.
  3. timerhan
    timerhan What's a Dremel?
    6 Nov 2012
    Aluminum structures look very impressive))))
    Polish it be?
  4. Mindphaser
    27 Jul 2010
    Thanks :rock:
    Not polishing - just painting.
    LennyRhys likes this.
  5. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Nice progress :thumb::rock:
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Holy moly, :jawdrop::clap::dremel: awesome progress Mindphaser, you clearly don't shy away from a difficult form to make. :rock::clap:
  7. KithKhan
    KithKhan A dremel is all you need.
    24 Feb 2012
    Sweet concept! Very cool.
  8. Mindphaser
    27 Jul 2010
    bluc, Waynio, KithKhan Thanks for the nice reference :clap:
  9. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: video card housing - update 20/11/12
    Back to the “coffin”:
    Finally, after many hours of adjusting parts, video card housing installed on the guide mechanism and tested in action:
    Now assembled frame with cover just hard to hold in hands and there is no normal position for its storage, have to immediately make a table mount:
  10. Overminde
    Overminde What's a Dremel?
    15 Sep 2011
    Its looking great. keep up the good job.
  11. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: table mount - update 28/11/12
    To keep at least some element of intrigue, I will not specify which item from the world of Half Life 2 was the inspiration object
    Basic set of material
    … and a baby carriage ?!
    Not all of course, only covers from the wheels
    Cutting, sawing, drilling
    Meanwhile another staff - find a paint for outside surfaces
  12. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: table mount - update 02/12/12
    Let's continue table mount making process…
    Since intrigue failed - just a screenshot
    I don’t really know what is it. Something links to the security screens in the Combine armory.
    Billets for "legs" from the aluminum angle
    Front support for legs
    Cool stuff :hehe:
    Frame complete
    Waynio likes this.
  13. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Wow.
    I've never played half life, so have no idea what that is, but it looks cool. Nice work.
  14. bluc
    4 Apr 2012
    Machine gun turrent :D
    Sent from my Nexus 7 using Tapatalk 2
  15. Skill3d
    Skill3d Minimodder
    29 Sep 2005
    Could it be the power source (battery) for the turret?
  16. Mindphaser
    27 Jul 2010
    It's really great idea to build UPS into the table mount. :thumb:
    Here a lot free space inside and UPS weight could make construction more stable :idea:
    Thank you so much for your idea :rock:
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    This has been impressing me from the beginning. :)
    It's been a while since I played half life so I didn't know what it was on the guess game but I always love seeing grab anything that works type modding like using a pram wheel for instance. :idea::D:dremel::idea:
  18. Mindphaser
    27 Jul 2010
    Heartily thank you for your genuine interest to my work :blush:
  19. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: DVD-box finish - update 09/12/12
    The DVD-box assembly process.
    Test assembly:
    Now I work in a bathroom too
    Prepare to sort components:
    My inspiration:
    Closer view:
  20. Mindphaser
    27 Jul 2010
    Combine Ceiling Turret: back to table mount - update 10/01/13
    New year – same mod )))
    Continue to make a table mount.
    Fiberglass sidewalls:
    Mains connectors:
    An aluminum decorative details:
    The nose part of the spray cartridge. There is the power switch with will be mount inside. Mold - zinc alloy shelf holder:
    Modified spray itself:
    Swivel mount holder for turret - furniture castor:
    All assembled
