Scratch Build – In Progress Combine Ceiling Turret
Discussion in 'Project Logs' started by Mindphaser, 11 Apr 2012.
  1. Mindphaser
    Mindphaser What's a Dremel?
    27 Jul 2010
    UPS table mount. Power ON
    Some progress…
    At first, kit for rust imitation:
    And then UPS table mount. Accumulators and UPS printed circuit board installed, wiring completed and power on:
    USB monitoring working too:
    Part of printed circuit board with RJ-45 protection was deleted (lack of inner space)
    Next time UPS table mount final assembly!
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
  3. Mindphaser
    27 Jul 2010
    UPS table mount final photo
  4. acmods
    acmods What's a Dremel?
    24 Nov 2014
    with a simple tools. it can be like this,,,, cool ...
  5. Mindphaser
    27 Jul 2010
    3D model
    Both turret and UPS-mount 3D model:
    Colors show work progress:
    Green – all ready
    Yellow – in process
    Red – even not start yet
  6. onevoicewild
    onevoicewild What's a Dremel?
    20 Dec 2014
    When Mods Attack! This is some crazy stuff man. Not OSHA approved!
  7. Mindphaser
    27 Jul 2010
    What is OSHA? Turret needn't to be certificated )
  8. Mindphaser
    27 Jul 2010
    Paining, again
    A lot of fresh painted parts photo.
    Assortment ):
    Shield, right:
    Shield, left:
    Video card housing parts:
    MB ports cover parts:
    A “lighter” (turret visual sensor system to detect intruders in its sight line):
    Its holder:
    Turret back holder:
    Arm swivel holder (joint UPS-mount and turret):
    “Power ON” indicator (door eye detected :)
    The one, on the place:
  9. Mindphaser
    27 Jul 2010
    Turret’s gun
    Well, its time to make turret’s gun.
    Barrel – aluminum body from pocket flash, flame arrester –permanent marker cap, threading parts - indicator light, PVC tube – light diffuser (filled with silicon):
  10. Mindphaser
    27 Jul 2010
    It's alive!
    Finally, ready to test assembly. Doesn’t looks like a turret, but operable )
    Testing area:
    Front part of video card housing – target aimer with machinegun barrel. Red light – power indicator, blue light – hard disk activity indicator.
    The one, in the dark:
    PCI-e x16 riser used, 100mm length. Temporarily, turbine from video card housing now cooling CPU radiator (CPU cooler in the housing alongside):
    Support for video card rear side:
    URL=http://www.radikal.ru][​IMG][/URL]
    Have to replace one 3’5” bay with two 2’5”
    Hardware monitoring screen (open case):
  11. d_stilgar
    d_stilgar Old School Modder
    11 Feb 2010
    Dang. This is really coming together. I can't wait to see it finished. Great build.
  12. Stallion
    Stallion What's a Dremel?
    30 Jul 2014
    Great detail
  13. Cheapskate
    13 May 2007
    The UPS looks like the real deal. This is going to look great!:rock:
  14. DanielSandsFTW
    DanielSandsFTW What's a Dremel?
    23 Mar 2015
    Looking amazing, can't wait to see more!
  15. Mindphaser
    27 Jul 2010
    Video card output box
    HDMI and DVI video outputs, 2xUSB 2.0, Front Audio connectors, AC power 220V connector, Power and Reset buttons.
    A lot of parts for assembly:
    Assembly in process:
    All ready:
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Awesome progress on this, good to see it still coming together. :)
  17. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    If Half Life 3 ever comes out, you should TOTALLY get a free copy from Valve. Great work!!
  18. d_stilgar
    11 Feb 2010
    I'm disappointed we don't have an emoticon of someone drooling.
  19. Mindphaser
    27 Jul 2010
    Visual sensor system
    A visual sensor system (turret from HL2):
    Rear parts painted:
    Rear parts assembled:
    Originally, this part has to detect intruders in its sight line. I used a domestic proximity IR sensor and controller with RGB-led.
    RGB-led status (depending of the systems state):
    • continuous green – no intrusion detected (no target)
    • flashing red – intrusion possibility detected (searching target)
    • continuous red – intrusion detected (target identified)
    Generally, visual sensor system looks like outdoor camera with IR-backlight:
    Assembled and mounted:
    LennyRhys likes this.
  20. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    My god man!!! Attention to detail is off the charts INSANE on this build!!! So much win!! :jawdrop: I'm starting to think you're going to make this into a real weapon!!!
