I was wondering if I could possibly get a bit of help combining errors. I have a few things I need to calculate the error for, and dont quite understand what im meant to do with some of them. They are all orbital elements. So what I know is the error in the distance between 2 planets, lets call this ed. I need help understand... Semi Major Axis The equation for this is... SMA = 0.5 ( distance2 - distance1 ) where both distances have error ed shown above. The combinational error I came up with was... dSMA = (1 / sqrt(2)) * ed[/d] which in itself im not massively confident about :S The other things I need to find errors for are... eccentricity = ( distance2 - distance1 ) / ( distance2 + distance1 ) where distance2 and distance1 again have error ed. Period = constant * SMA^3 where the SMA = 0.5 ( distance2 - distance1 ) Basically I just cant work out from my notes how I am meant to be combining some of this stuff :S There are more but tbh once I can work out the ones above I can get the others quite easily. Thanks for anything!
Had a look at my own notes on errors and managed to flesh this out for you mate. Hope it helps! p.s. Anyone spots any mistakes, feel free to correct/berate me, I'm not massively good at errors myself. [edit]Bloody pdfhost... right load of rubbish! [edit2]Just noticed a mistake, right at the top, distance 2 = some value +/- sigma, not 2! :\
Thanks krikket Im shocking at errors, half the reason I changed to computational physics, not nearly as many errors to worry about Computers do things so much better than someone (me) in a lab! edit: does make me feel good about getting the SMA right though \o/
what course is that? if it is chem what year as i aint done that sorta thing yet in my uni course tho have only just really started 2nd year so meah. tho if i should have donw it oh bugger i need to go over my notes
Physics. The one thing they absolutely go sick for in a Physics degree is error analysis, and it makes me a very sad panda...
Computational Physics Error makes me sad too, but since this is the first I have needed to do since second year it isnt too bad
