Development Combining SQL queries
Discussion in 'Software' started by Firehed, 13 Jun 2009.
  1. Firehed
    15 Feb 2004
    Hey all,
    Haven't been around much recently as I've been quite busy with a startup, but I've got a quick SQL question. I've basically got a transactions table in my DB set up in the way you'd probably more or less expect: id, amount, sender_id, recipient_id, and some other fields that are quite irrelevant to the discussion.
    Is there a good way to calculate an account's total transaction history in one fell swoop? It's easy enough to do two "SELECT sum(amount) as sentTotal FROM transactions WHERE sender_id = X" type of queries and combine the values externally; just wondering if there's a "cleaner" way to do it.
    Thanks!
  2. Hamish
    Hamish New Member
    25 Nov 2002
    so you want the sum of account where the user is the sender and another sum where they're the recipient?
    2 sub-queries?
    self-join?
  3. VipersGratitude
    VipersGratitude Well-Known Member
    4 Mar 2008
    WHERE
    sender_id = "X" OR reciever_id="X"
  4. Firehed
    15 Feb 2004
    The value has to be subtracted in one case and added in the other.
  5. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    Something like the following would probably do
    Code:
    select isnull( S.sender_id , receiver_id ) as ID, sentTotal, receivedTotal , isnull(receivedtotal,0) - isnull(senttotal,0) as [ACCOUNT TOTAL]
    from (
    SELECT  sender_id, sum(amount) as sentTotal FROM transactions
    group by sender_id
    ) S outer join (
    SELECT reciever_id, sum(amount) as receivedTotal FROM transactions
    GROUP BY RECEIVER_ID) R on S.sender_id = R.receiver_id
  6. Daedelus
    Daedelus New Member
    7 May 2009
    This might work - I can't actually test this, I've just written it 'blind' and it's probably inefficient.
    (I've assumed your table is called 'transactions')
    Code:
    SELECT account_id, total1.total, total2.total FROM
    	( SELECT DISTINCT sender_id AS account_id FROM transactions t1 UNION ALL SELECT recipient_id AS account_id FROM transactions t2 ) as account_id a
    	LEFT OUTER JOIN	(SELECT sender_id, SUM(amount) as total FROM transactions GROUP BY sender_id) as total1 ON total1.sender_id = a.account
    	LEFT OUTER JOIN (SELECT recipient_id, SUM(amount) as total FROM transactions GROUP BY recipient_id) as total2 ON total2.recipient_id = a.account_id
