Windows Command & Conquer Generals Deluxe Edition
Discussion in 'Gaming' started by BlueOcean, 24 Jun 2010.
  1. BlueOcean
    BlueOcean What's a Dremel?
    5 Feb 2008
    I have installing the game on computer. The game didn't work with windows vista.
  2. Gh0stDrag0n
    Gh0stDrag0n Unleash the Beast!
    16 Aug 2007
    Have you tried running in Compatibility Mode?
    -Left click on game Icon
    -select "Properties"
    -click "Compatibility" tab
    -check "Run this program in compatibility mode for:"
    -choose mode in drop down list
    -click "Apply"
    -run program
  3. Cabe6403
    Cabe6403 Supreme Commander
    3 Apr 2007
    This. Use XP mode and it should be fine. If it still doesn't work check your error logs. I seem to recall there being some issue with Generals and DirectX 10
  4. BlueOcean
    5 Feb 2008
    I try it already didn't work on windows vista. If still not work. I forget it.
  5. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    It does work on Vista; I've got the 10 years of C&C pack and all the games work. Get the latest patch from the EA website and it should sort you out.
  6. Abhorsen
    Abhorsen Minimodder
    10 Apr 2008
    It also works on w7.
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    I think there was some issue with the path to the user folder on Vista.
    Works fine on 7 though so i don't know...
    Maybe you should upgrade to 7 after all? :p
  8. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    The only thing I can think of is to patch it... I have Vista and it works perfectly well, apart from the online mode, that's never worked.
  9. lcdguy
    lcdguy Minimodder
    25 May 2004
    when i had vista i did manage to get it going but it was not easy. If i remember correctly it's looking for a configuration file in a specific path that doesn't exist since documents and settings is gone. I think you need to create the structure so it can put the file there or something. also the affinity could be messing with it as well. Try setting the affinity to 1 core or if possible use a tool like imagecfg to change the affinity mask on the executable.
  10. Bungletron
    Bungletron Minimodder
    25 May 2010
    Not sure its worth the hassle, although I would install it to hear just one soundbytes again:
    'AK47s FOR EVERYONE!'
  11. trekkypj
    trekkypj Forward Momentum!!!
    23 Jun 2010
    The only thing I can think of is that you may need to run the game in Administrator mode.
    Not sure that's any help but it helped me to get Medieval 2: Total War working on Win 7 64bit so thought I'd mention it.
    Other than that, could be you have to check 'under the hood', as other posters have said. May be a user folder issue as someone else mentioned.
  12. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    I had a similar problem. You need to create the folder tree and prefs.ini I think, but I can't remember what the folder tree is sorry.
    Don't give up :)
  13. lcdguy
    lcdguy Minimodder
    25 May 2004
    i did some searching and did find some promising information on another forum but i am not sure if posting to other forums is allowed so search for something to do with options.ini
  14. lp rob1
    lp rob1 Modder
    14 Jun 2010
    Generals works with me on w7... no .ini tweaks or folder structures needed
  15. BlueOcean
    5 Feb 2008
    Windows vista it work with command & conquer generals.... The command & conquer generals zero hour didn't work with windows vista at all.
