Case Mod - In Progress Commodore P.E.T. 2011 - Problems!
Discussion in 'Project Logs' started by TheGreatSatan, 16 Mar 2011.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    Windows doesn't even see it till I confirm it on the buttons. Even if I move the buttons I still have to deal with it every time I boot up. It's just too pointless.
    While I think of the monitor, I got back to the keyboard. I got it to fit
    I'm purposely using this rusted old piece of steel. I think it's a perfect choice for such an old computer
    I attached the keyboard but left the original screw posts to hold the steel in place
    Then I cut the holes and added the screws
    I also made it big enough to back the keypad too
    So once again I have to fill the void. I'm not sure what to use just yet
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    You should be able to get one of these that fills the hole.
    For the screen, how about using a double pole switch for power?
    Use one pole to turn the pc on, the other to switch the screen to "monitor mode".
    Like this:-
  3. TheGreatSatan
    5 Aug 2005
    I got the keypad. I meant the void around the edges of the keyboard
  4. TheGreatSatan
    5 Aug 2005
    I got this old-school style USB keypad
    I cut away all the excess and got rid of the NumLock LED
    With a tiny bit of trimming the opening, I got it to fit
    Then I just had to put the sheet metal back on
    And that's done
  5. KidMod-Southpaw
    28 Sep 2010
    Bloody hell, I want it! What a great job.
  6. sinner666999
    sinner666999 What's a Dremel?
    3 Jan 2011
    Looking really good. Happy to see you decided to make use of the keyboard area and put a monitor in there as well.
    Can't wait to see more progress.
  7. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    No drill bits?
  8. TheGreatSatan
    5 Aug 2005
    No! I had run out:jawdrop:
  9. TheGreatSatan
    5 Aug 2005
    I used the motherboard from Project Boom Tube so I could test the screen. I had to plug in one of my LED fans because I could literally not hear it to know if it was even on. But what do you expect from a fanless CPU and an SSD drive?
    And it seems fine
    The weird thing about this screen is that it comes with a serial port connection
    I guess it's a touch screen? Luckily my MSI 870 does have a rear serial port. Later, I'll see if I can get this feature working
    The problem is, getting all this stuff in the case with the PSU next to it. At least that's where I have an extra fan
    The LCD fits, but I'll have to cut out this plastic mold where the old CRT was mounted
    Once that's cut out, I'll just have to make a black framing to go around the edge of the LCD
  10. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    looks pretty good, I think a touch screen would be pretty neat in there
  11. TheGreatSatan
    5 Aug 2005
    So I got the molding cut out
    And when I put the LCD in, the PSU no longer fit!
    So I'm going back to the Kodak touch-screen photo frame. I want to have it play photos of the build and some old pics of Commodore's past
    It just needs a small amount of framing to make it perfect
  12. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    maybe get some c channel to hide those rough edges around the keyboard / keypad. that plastic does look rather thick though. too bad about the touchscreen not fitting properly.
  13. KidMod-Southpaw
    28 Sep 2010
    It's too bad it's too impractical to use as your main monitor, still, I love it and I'll vote for you in MOTM!
  14. TheGreatSatan
    5 Aug 2005
    I was thinking black silicone caulk maybe?
  15. GreatNorthWeb
    GreatNorthWeb What's a Dremel?
    9 Apr 2011
    ...that really was a killer mod! I would love to see a video where you are running the VICE PET emulator on that. old=new=old again
    Do you still have the guts from that beast? My PET2001-8 power supply died this morning. I would be willing to buy all your bits and pieces to use as spares to keep mine alive but I live in U.S.
    Fun project.
    jason
  16. TheGreatSatan
    5 Aug 2005
    I need to remove the gaps around the LCD, so I'm going to be using this old side panel from a cheapy Thermaltake V3
    Measure six times and then cut once
    I'm using a flat black to get rid of the "shiney" look too
  17. TheGreatSatan
    5 Aug 2005
    I got the LCD frame in
    But there's an annoying gap all the way around.
    The fix is black caulk
    And that's it. I will take a few days to fully cure, but when it does it'll look a lot cleaner
    Next are the components!
  18. TheGreatSatan
    5 Aug 2005
    UPDATE:
    I'm going from 6GB to 16GB of RAM!:rock:
    It just makes sense to make the specs on an ancient Commodore crazy high
  19. KidMod-Southpaw
    28 Sep 2010
    Sexy memory! I hate to say it now, but you'd have been able to use a real screen in there if you hadn't used a full size psu.
  20. TheGreatSatan
    5 Aug 2005
    Yeah, you're right
