Scratch Build – In Progress [Compact Splash] mini pc gamer
Discussion in 'Project Logs' started by failariel, 22 Jan 2014.
  1. failariel
    failariel New Member
    7 Feb 2012
    greetings to all ...
    I apologize in advance because I am Spanish and do not speak English ..
    and I have to use a translator. But somehow I want to share the work conducted under the this wonderful box
    the idea of the project is to mount a pc gamer with liquid cooling in the smallest possible dimensions.
    is because my desk space is very small and with this box you can get to do something good.
    S P E C S
    C A S E - S P E C S:
    - Case No: 55
    - Color: glose white pearl
    - Side Panel: Black Smoked Acrylic
    - Power Switch: Delrin / Red LED
    - Front I/O: Yes
    - Radiator Screws: M-3
    - Drainport: yes
    - Fillport: Yes
    - Name Plate: VITO
    H A R D W A R E:
    - CPU: i7 4770k
    - GPU: evga 780ti
    - Ram: 16gb dominator platinum 2400mhz
    - MOBO: Asus Impact
    - Storage: standby
    C O O L I N G:
    - CPU Waterblock: Bitspower AIZ87M6IITX Nickel Plated (ICE Black)
    - GPU Waterblock: ek 780ti plexi
    - Reservoir: bitspower 40cc depotop
    - Fittings: EK-HD Adapter 12/16mm - Nickel
    - Tubing: Acrilic tube
    - Liquid: Mayhems Pastel Red
    - Rads: XSPC EX240 & 120
    SPONSORS:
    thank you all for your attention! and I hope to live up ^ ^
    pics of the compact splash
  2. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    You need to post an actual log with some work done rather than a list of components with no pics or work....
  3. failariel
    7 Feb 2012
    here are the psu and finish the sleeving
    the mobo
    here the extreme-water and pcrelic sponsor
    start to mount blocks
    the depo of ddc
    starting a little testings
    here the box arrived
    front IO + switch black / red led
    ready to paint
    acrylic tubes ready
    the logi sponsor
    the painting work
    and that is the work so far.
    I hope from this point to update every day.
    tomorrow I start work on customizing the backplate and hopefully next week and be able to start riding hard in the box
  4. jrs77
    jrs77 Well-Known Member
    17 Feb 2006
    Nice looking case so far.
    Could you give some more information about the case you're using there? Who manufactures them, who sells them, etc?
  5. B NEGATIVE
    8 Aug 2011
    Dwood on OCN makes them for She loved E. All sold via OCN as part of their ridiculous artisan rules.
  6. jrs77
    17 Feb 2006
    Too bad really.
  7. failariel
    7 Feb 2012
    if the box design and the SLE was a limited series of 105 units. has a 14.5L inside so it is one of the smaller boxes I've found to mount a rl. my idea is to mount a gamer hardware in small dimensions
    here are a pic of the bof with a normal paint
  8. failariel
    7 Feb 2012
    I know the box was also sold from your personal page
    http://www.craftograph.com/compactsplash/
  9. failariel
    7 Feb 2012
    i start a test in the backplate
