Case Mod - In Progress Compact Splash - Schwarz Nickel
Discussion in 'Project Logs' started by Jeffinslaw, 14 Jul 2014.
  1. Parge
    16 Jul 2010
    MOAR ITX goodness.... Total nergasm. What colour are you thinking for the coolant?
  2. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    I was just thinking it would help clear the clutter a bit in front of the res, but it would require another right angle fitting, or one hell of a tight tube bend to connect the rads. Kinda hard to keep anything really neat in a space that small! Hell I can't keep anything neat in an M8 cube, I'd be LOST with a compact splash. :D
  3. Jeffinslaw
    Jeffinslaw What's a Dremel?
    26 Jun 2014
    I'm going to be changing to EK nickel compression fittings and some EK ZMT tubing so I'm going to stick with the distilled water. I like the simple look of it!
    Yah... getting the tubing on the bards was pretty difficult... I think I'm going to leave it as is for now.
    -Jeffinslaw
  4. Jeffinslaw
    26 Jun 2014
    Final Pictures
    Well guys, here they are, the final pictures! Boy was this a fun build to do though. Very pleased with the final product. There are a few things I want to upgrade/change but I need a monitor first. Looking to get the 25" 1440p Dell. Just need to save about another $250.
    Anyways, on to the pictures. I'll let them do the talking!
    Thanks for following along guys! Hope to see you all for the next project! :rock:
    -Jeffinslaw
  5. Zoyadog
    Zoyadog What's a Dremel?
    28 Jan 2014
    Wow that looks so nice! I like it very much, especially the cables and tubing. Love the flow in that. And i dont think you need coloured coolant. Well done!
  6. Jeffinslaw
    26 Jun 2014
    Thank you! Glad you like it!
    -Jeffinslaw
