Build Advice Compatabilty Check
Discussion in 'Hardware' started by Bench3, 10 Oct 2012.
  1. Bench3
    Bench3 What's a Dremel?
    10 Oct 2012
    Hey, I'm building my first PC so just making sure I get it right.
    Can somebody check if all these parts are compatable and if not tell me?
    (It's a gaming, recording and editing rig)
    Thanks :D
    3.5GHz Intel Core i7 3770K 4-Core Ivy Bridge CPU
    MSI Z77A-G45 Intel Z77 Socket 1155 Ivybridge Ready Motherboard
    EVGA 2GB GeForce GTX 670 NVIDIA Graphics Card
    Corsair Memory Vengeance 16GB DDR3
    Seagate 1TB SATA 3 Performance Hard Drive
    NZXT Phantom White Gaming Case
    Corsair Gamer Series GS600 80+ 600W PSU
    Xigmatek Aegir Air CPU Cooler
    Any help will be much appreciated,
    Thanks in advance,
    ~Ben :D
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    You could drop to the 3570K to save quite a bit of money for very little performance loss.
    Might be worth it to get an Asus or Gigabyte motherboard instead of MSI. How about the GA-Z77-D3H?
    I've heard the Corsair GS series isn't quite as good as other Corsairs. Maybe worth checking out other PSUs.
    Do you have an SSD? Definitely worth squeezing in somewhere.
  3. Cei
    Cei pew pew pew
    22 Mar 2008
    If this is a gaming rig, which it looks like with the 670, then I would drop the CPU to a 3570K and spend the resulting savings on an SSD for Windows to run off. You'll end up with a much more responsive system.
    I'd also say that 16GB of RAM is way too much for a gaming rig. 8GB is plenty.
  4. Bench3
    10 Oct 2012
    Even for recording/editing?
  5. Cei
    Cei pew pew pew
    22 Mar 2008
    Recording and editing what? You need to be a bit more specific about your intended use here.
  6. Bench3
    10 Oct 2012
    Sorry.
    Recording gameplay footage of high quality games on high settings and rendering out high quality videos with high quality software.
  7. Cei
    Cei pew pew pew
    22 Mar 2008
    I'd still say it is overkill, both CPU and RAM. Whilst it is true a 3770 is "better" at rendering (ie: does it a bit faster) it generally isn't worth the cost premium in most cases. Same for RAM, although you can always add more RAM later if you really do feel constrained.
