Hi all, Does anyone know of any cheap Ram that works with an AM3 Asus M4A78LT-M. Im buying from Scan so I would like to get the ram from them if possible. The Ram I was looking at was : Corsair Memory XMS3 4GB DDR3 1600 MHz CAS 9 XMP Dual Channel (CMX4GX3M2A1600C9) as its only £36.14 (out of stock atm I know). Any replies welcome. Regards.
http://www.scan.co.uk/products/4gb-...00-(1600)-non-ecc-unbuffered-cas-9-9-9-24-15v Here you go. I have the 8GB kit myself running in my SB rig. I just presumed you wanted 4gb.
Just checked the RAM you suggested on Corsair Website and it only lists Intel CPU compatible mobo's. Yet on Scan it says it is for "AMD Phenom and Intel Core i3, i5 dual channel memory processors".
It's fine. Trust me on this one. I've had it running on my brothers AMD rig thinking a stick was faulty.
