Hmm, my sparkplugs are looking a little worn out. I'd better get those fancy ones with four 'spark points' - should net me another 2-3FPS in Metro 2033 and Crysis.
i was thinking about upgrading the trainers on my rig im not so happy with puma's overclocking ability im thinking about moving to addidas they normally take more wear
It's wierd, I tried to upgrade my computer by buying some Nike trainers, but I don't know where to place them. I tried super-gluing them to my CPU, but they caught on fire. I then tried fitting the remains inside the optical drive, but it started to make wierd noises, and started giving off some strange smelling smoke. I need some help guys
Its fairly standard practice to ask a silly question. I think there is different legislation covering prize draw where there is no question just a name in a hat compared with a competition even though the answer is so easy it might as well just be a raffle.
I tried combining the three and my PC grew legs and hopped through a black hole before it disappeared with a really loud farting noise.
What silly question? @Siberdine: You're supposed to put the trainers on the PSU using UHU - makes it put out more power - hence why you need better spark plugs to deal with the extra electrons. Bums' hat mod also keeps the electrons in the case which is why his computer runs faster.
Sneaky buggers that's obviously a trick question, everyone knows powerbands make everything go faster.
Screw those answers, I was going to add a NOS system directly into my CPU. That will make it go fast right?
LOL, OT but that reminded me when I first got into modding I was considering a stupidly over-done ricer theme. one of the ideas was to find somewhere to mount one of those compressed air cans up-side-down(so it would spray more of the chemical out and fog)and direct the straw toward the cpu heat sink and then on a button push it would blow into the HS.
Are you lot STUPID or what? Every one knows that a go faster stripe is all you need. The clue's in the name you bunch of noobs!!!
Funny I was just considering adding more hampsters and spinning wheels to mine! EVERYONE knows thats the way you speed things up. More hampsters + spinning wheels= more power and heat disapation!
