Scratch Build – In Progress COMPLETED ! 00 project
Discussion in 'Project Logs' started by Antera23, 26 Jun 2016.
  1. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Hi everybody!
    My name is Peter Bartos , from Hungary, Budapest.
    This is " T.U.F. project " ...Tolilet Ultimate Force
    Monoblock toilet pc. /water cooling/
    Used materials:
    -Policarbonat
    -Plexi
    -Plywood 4mm
    -Tiama wood
    -Steel frame
    Hardware :
    -AlphaCool Alphacool VPP655 PWM D5 plexi
    -AlphaCool hard tube plexi 13/10
    -Phobya UC-2 LT
    -AlphaCool NexXxoS GPX - Nvidia Geforce GTX 960 M02
    -AlphaCool fittings
    -CoolerMaster V850
    -Asus Sabertooth Z170s
    -Asus Strix 960 GTX 2Gb OC
    -Intel I3 6100
    -TeamGroup Delta DDR4
    -Geil Zenith R3 120Gb
  2. Antera23
    Antera23 Minimodder
    14 Jan 2007
    ...he started.
    Thanks to the sponsors!
    -Asus Hungary
    -CoolerMaster Hungary
    -TeamGroup Team Taiwan
    -Geil
    -Aquatuning
    -Geberit Hungary
    -Kerttrade Hungary
    -Dremel Hungary
    The frame
    Hardware:
  3. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Cup
    25 layer policarbonat
    24 layer plywood 4mm
    Motherboard tray
    Policarbonat
  4. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Geberit frame modding
  5. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Tiama wood
  6. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Geberit frame update
  7. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Cup holder
    5mm stainless steel.
  8. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Radiator
    Suzuki Swift heating radiator mod.
    Home-made
    Aluminium glue
  9. Antera23
    Antera23 Minimodder
    14 Jan 2007
    DIY temp meter.
    -Test tube
    -Cristal Nails Chameleon gel
    Test home Pc
    Idle blue...
    50'C pink
    Test ok!
  10. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Motherboard tray
    Policarbonat 10mm
  11. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Dremel Moto-Saw.
    Cup : Plywood 4mm , 25 pcs
    external size : 400*500
    internal size : 400*300
  12. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Cup layer plans
  13. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Power Supply
  14. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Woodwork
    https://scontent.ftsr1-1.fna.fbcdn.net/t31.0-
    8/11262105_1245528422128517_8347648402826515596_o.jpg
  15. amagriva
    amagriva Minimodder
    13 Jun 2009
    I'm not sure to have completely understood what will be the outcome of your struggles but I see you have the skills to succed so mod on I'm waiting eagerly updates! :thumb::thumb:
  16. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Hello,
    Thank you, i'm glad you like it.
    This is a modern monoblock toilet .
    Asus TUF serias motherboard is the heart of the machine .
    The Ultimate Force.
    Military grade. Perfect in all circumstances.
    The most difficult combat conditions are in a toilet . :D
    Bye
    Peter
  17. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Motherboard tray led lighting.
  18. Antera23
    Antera23 Minimodder
    14 Jan 2007
    trial installations
  19. Antera23
    Antera23 Minimodder
    14 Jan 2007
  20. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    So not a functional toilet then. Still a great case idea.
    An extra pat on your back for managing to do a sponsored build around a toilet... So many bad jokes/puns that could be made about the hardware and manufactures and the toilet.
