Case Mod - In Progress [Completed] IBM PC-AT - Update 3rd, October - Painted and Built
Discussion in 'Project Logs' started by Mosquito, 4 Apr 2011.
  1. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Index
    Update 1 - 4th, April - Emptying the box
    Update 2 - 9th, April - Frame and Back Panel
    Update 3 - 17th, April - Fans and power switch
    Update 4 - 1st, May - Front Fan Mounts Finished
    Update 5 - 3rd, May - Monitor Mod
    Update 6 - 19th, May - Cable Sleeving
    Update 7 - 16th, June - Almost Done!
    Update 8 - 3rd, October - Painted and Built
    Introduction:
    Hi all,
    First off, this is my first major mod, and my first project log, so with that in mind, please be kind :D That said, helpful tips and suggestions are very welcomed!:dremel:
    Ok, so this project is something I've wanted to do for a while. The back story is that I have always liked old computers (old to the point that they're "cool" or "vintage", not just some PII machine). I currently own an Apple IIGS, a Toshiba T2000SXe, and an IBM PC-AT (5170) all of which are in working condition :)
    The Idea
    I wanted to do a mod of an "iconic" old computer case, and I decided to go with an IBM PC-AT 5170 case. I will be modifying this case to fit my current desktop components. The main hardware:
    • GIGABYTE mATX Motherboard
    • Intel Core2 Quad Q9400 2.66GHz @ 3.0GHz
    • 8GB G.Skill DDR2 800
    • 2 x OCZ Vertex 2 60GB SSD
    • 750GB Seagate HDD
    • Lite-On Bluray/HD-DVD combo drive
    • Lite-On DVDRW Drive
    • Sapphire ATI 5750 Vapor-X, but have a 4850x2 that will hopefully be put into this build
    • Hauppauge 2250 TV Tuner
    • Silverstone 850W Modular PSU
    The Mod
    These are some of the "concept" pictures:
    The idea of the finished project (though the drives will be different, just a concept):
    "Mock-up" of the parts in the case cover to check fit:
    More to come shortly!
  2. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Update 1 - 4th, April- Emptying the box
    Update - 4th, April
    So after a month of anxiously waiting my case was finally delivered.
    Here's the front, it doesn't look so bad...
    But then again, maybe it's going to need some work...
    Ok, that's for later anyway, so I won't worry about that now.
    After taking out the parts that came in it (non-original parts) I was left with what I wanted. Some parts in it to test the fit of things
    Now, on to the fun part:
    Since it was a nice sunny 45F (7C?) outside, I decided to take my modding outside.
    I decided to start by making an attempt at taking out the hard drive cage that needs to move:
    Right, so that wasn't quite going as well as I was hoping at that point... I needed to drill out some spot welds to get the cage out, and I couldn't get to them. So I turned my attention to the rear PCI slot dividers that also needed to be removed. Hoping that with my 12" drill bit I'd be able to get the drill back far enough to get at the spot welds with that part gone.
    Did I mention there were a LOT of spot welds holding this thing together?
    Doesn't appear to be so bad:
    On the other hand... maybe not so good either
    It was at that point I decided that I'd be cutting off the whole back, and making my own rear brace section (was already planning to cover the whole back with 1 piece of steel anyway).
    After packing up, and eating some dinner, I then moved things into the garage to tackle that hard drive cage again.
    I then started taking off the remaining mother board support braces that were there
    Apparently my screw driver was slightly magnetized...
    I then cut off the back that I had mangled earlier
    This little bit was just hanging there after the pass with the jig saw...
    I drilled some rivets and got myself a motherboard tray and back plate out of an old donor case and trimmed it up a little so it wouldn't be too long. I set that in there to see how it would fit, and it looks alright, I'm pretty happy with that.
    A decent collection of scrap metal at this point, so I called it a day. Up for some fun in the next update, I will tackle the back brace that I am going to need after mangling the first one.
    Until then thanks for viewing!
    -Mos
  3. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Update 2 - 9th April - Frame and Back Panel
    Update - 9th, April
    Back at it again, over the past few days I built an aluminum frame support structure for the back of the case, to hold the top up.
    Unfortunately, I don't have any pictures of the rest of it, but I put 3 braces that run from the back to the front, to keep the back straight when putting the top case on or taking it off. You can see the three braces in some of the other pictures.
    Today's work station, more or less
    Here you can see the 3 braces, also, I cut a piece of 1/16th" thick steel for the back plate which can also be seen in these pictures
    Then I cut out the hole for the I/O plate and the PCI slots, which I bought from Danger Den, instead of using the one I cut out earlier.
    After that, I cut out a hole for the power supply to be mounted
    That's about all I've got for this update, but it was some pretty good progress. I got done today what I wanted to get done, so I'm happy with it. Next update will hopefully be some fan mounting.
    Until next time, thanks for taking a look!
    -Mos
  4. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Man, that thing is a tank!
  5. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Pretty much... it weighed 39 pounds shipped... I should weigh it again sometime and see where it's at now :)
  6. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    those old case with 2mm steel are very tough to work on. but you managed to get it done well. if the front needs some attention from yellowing you might look on retrobrite.
    now you need model m keyboard, 1 button mouse and crt to complete the look.
  7. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I would love to obtain the set to finish the look. I have a full set of working hardware, and when this is finished I may do a side-by side shot or two. I am currently pursuing a lead on a possibly non-functioning keyboard to get my hands on. As for the CRT, that bit may be a little more difficult. It's unfortunate that not everyone holds on to their old non-working parts the way I seem to :blush: (or at least they're not selling them) So anyone with an old IBM Keyboard or CRT monitor (non-working) that would be willing to ship them in the States... you may have a buyer ;)
  8. IvanIvanovich
    31 Aug 2008
    theres a bunch of model m keyboards on ebay all of the time, if you keep an eye i'm sure you can get a working one under $20. if you need to you can always get an at / ps2 adapter for it.
    if you're interested in a *working* ibm monitor i actually have one, though i understand not wanting a working one with the tube inside as it would cost very much for shipping, it weighs probably 80 lbs.
    if you're near minneapolis theres lots of used stores and flea markets that often have crts for $5-20.
    edit : here you go, http://cgi.ebay.com/1985-IBM-F1-Mod...801?pt=LH_DefaultDomain_0&hash=item3366dc2a01
  9. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Update 17th, April - Fans and Power Switch
    Update - 17th, April
    I got a few packages in the past few days, containing some fans, a power switch, and a few other odds and ends. Nothing much major in this update, but they're things that need doing, and it's all I've got for now.
    Right, on with the pictures, first I received and installed the 60mm fans in the rear.
    Then, a day or two later I received the 120mm fans for the front of the case, and created one of the two brackets for holding the fan
    Along with this, came the first casualty of the mod:
    Luckily I had a spare, so I was able to carry on. Finished shots of the one fan mounted in the newly made brackets
    Then it was on to the fan plug multiplier, and the mounting of the power switch
    A little filing was required to get the switch to fit. A little uneven, but it is hidden from view, so I can live with it. It will work.
    And then, the second casualty... I managed to break a fan... oops... looks like I will be ordering another 60mm fan....
    That is all for this update, stay tuned for more!
    -Mos
  10. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Maybe I was just being too picky, but I guess I was looking for a specific version of the model M keyboard... but maybe I'll go for the one you posted, it's cheap enough that even if the look isn't 100% what I was going for, it still fits the role well
  11. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Update 1st, May - Fan Brackets finished
    Update - 1st, May
    Work has been a little slow on this project lately, for that I apologize, but it isn't dead. I just don't have very much in the way of major work. I have mounted the second fan, and cut out excess aluminum on the fan brackets, drilled holes for attaching the motherboard tray to the frame, and made a bracket to hold a hard drive into the 5.25" bay, which will be scrapped for something else to hopefully hold 2 SSD's and a hard drive.
    Enough talk, on with the pictures.
    Cutting the excess out of the first set of fan brackets
    Drilling some holes in the second fan bracket assembly, and the second fan mounted, and both mounted
    And a little bit of what's to come...
    -Mos
  12. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Update - 3rd, May - Monitor Mod
    Update - 3rd, May
    Last week I had bought and gotten a non-working IBM PC-AT (5151) monitor. I also got a Daewoo 12.1" LCD monitor, which I received on Monday. I gutted the Monitor of its parts and then I installed the LCD screen into the old monitor body.
    That is all for this update, hopefully I will have more work done shortly. I also got the parts I needed for the SSD and HDD installation, and hope to get that squared away. After that it's down to paint and final assembly!
    -Mos
  13. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Update
    Update - 19th, May
    A minor update I guess. I have more, but it goes with the next update. I have done some cable sleeving of fans, SATA cables, and the power switch/LED leads.
    I also purchased some black fan plugs that I swapped in for the brown/white ones in these pictures.
    I ran into a bind for mounting the hard drive and my SSD's... the bottom 5.25" bay ended up being about 2/3's the height of a normal 5.25" bay so my plan didn't work. So now I will be figuring out a new place to mount the SSD's while mounting the hard drive in the smaller 5.25" bay somehow. Then it's time for finishing this thing!
    -Mos
  14. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Update - 16th, June - Done! (almost)
    Update - 16th, June
    It's done! (almost)
    These are pictures from when I used some of my "spare" hardware to see how things fit. Cabling is a little tight, but I think I can make it work. I don't have a picture with the top cover on yet, but may update later tonight with some. The front lower optical drive is missing a screw on the front left rail, because that drive has stripped threads. With the actual drive it will be straight like the other one.
    Hoping to get this painted in the coming month or two, and then this will be 100% done!
    Thanks for taking a look!
    -Mos
  15. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    oops, double post
  16. KidMod-Southpaw
    28 Sep 2010
    Looking very nice, I love it!
  17. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    yea, really good, and nice to see someone else who likes desktop :)
  18. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    Thanks! This was something I wanted to do for a while now. Currently what I have left is just paint and hardware install. Hoping to get it painted soon...
  19. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    you should start to watercool it
    with dual 240mm's and then cram stuff in until it blows like a ballons
  20. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I was actually throwing around the idea of a single 240 in the front where the two fans are now, but didn't like the lack of airflow to the rest of the components that way. That and it'd be my first water cooling adventure, and I don't know that I'd want to do it on 3 year old hardware lol
