Case Mod - Complete {Completed} Project: Gold Rush (24ct Gold)
Discussion in 'Project Logs' started by MT. Mods, 20 Jan 2017.
  1. MT. Mods
    MT. Mods Case Modder
    6 Apr 2016
    Hello, Welcome to the logs for GOLD RUSH.
    What is Gold Rush ?
    Gold rush is an exotic project with 24ct gold plated fittings, Backplate, and whatever else i can get my filthy paws on ;)
    The case it's self will be, cut up, and resprayed in a white/gold flip paint.
    Featuring a parallel loop and a gold mine on the shroud, this project will be a show stopper.
    Special Thank You
    I'd like to take this moment to thank some of the greatest people who made this whole project possible.
    Alphacool - https://www.alphacool.com/
    CableMod - https://cablemod.com/
    Cooler Master - http://eu.coolermaster.com/uk/
    ASUS ROG - https://rog.asus.com/
    Team Group: http://www.teamgroupinc.com/en/index.php
    Without these guys, this project wouldn't have made it past the design stage.
    SPECS! We all love a good read at this part
    From Coolermaster
    Cooler Maser MasterCase Maker 5
    Cooler Master V1000 PSU
    Cooler Master Masterfan airflow 140mm
    From Alphacool
    Alphacool Eisblock XPX CPU - Intel/AMD - silver matte
    Alphacool NexXxoS XT45 Full Copper 280mm radiator
    Alphacool NexXxoS ST30 Full Copper 280mm radiator
    Alphacool NexXxoS GPX - Nvidia Geforce GTX 1070 M02
    Alphacool Eisbecher 250mm Acetal reservoir
    Alphacool VPP655 PWM - G1/4 inner thread including Eisdecke D5 - Acetal V.3
    Alphacool Eisrohr 16/13mm PETG HardTube
    Alphacool Eiszapfen 16mm HardTube compression fitting G1/4
    Alphacool Eiszapfen angled adaptor 45° rotatable G1/4 outer thread to G1/4 inner thread
    Alphacool GPX SLI Connector - Single - Plexi
    Alphacool double nipple G1/4 outer thread to G1/4
    Alphacool angled adaptor 45° - G1/4 revolvable - 2x inner thread
    From ASUS ROG
    ASUS Maximus IX CODE Z270 Motherboard
    ASUS Strix GTX 1070 Graphics card
    From Cablemod
    Gold /White Modflex full PSU kit.
    RGB-W Hybrid LED kit + 3 extensions.
    From Team Group
    T-Force XTREEM DDR4 RAM
    Other parts
    CPU - i7 6700K
    Design
    i've never been very good at 3D modeling software, so i do my best in words to describe the mess in the image lol.
    Now a few things to point out.
    The loop under the GPU will no longer be zig zagged, it will be a straight 45 degree angle from GPU to Shroud.
    Around the base of the reservoir and where the fittings meet the shroud, there will be pyrite fools gold set around them, like gold is forming around a hot chamber.
    The name ''gold Rush'' will be cut from the shroud, and filled with pyrite (Fools gold) for a more authentic look.
    Sponsor logo's on the front will be made from real 24ct gold leaf.
    The gold triangles you see on the case will be cut outs, and meshed for looks and ventilation.
    The mesh will be gold too.
    Time Frame
    I'm guessing at 4 weeks, as this is the biggest project i've undertaken yet and by all means the toughest work yet.
    Over the next 4 weeks i'll be doing a VLOG of the build progress, out on the road, at home, wherever i need to go, be sure it'll be on video.
    i expect 4 episodes 1 for each week.
    Don't fret, as pictures will be uploaded as i go for the project logs and social media.
    Teaser
    All parts are on route to me as i type this, so expect work to begin in just a few days.
  2. MT. Mods
    6 Apr 2016
    Some things arrived yesterday.
    1. Gold plating solution (24ct) Strange it came with silver, maybe next builds ? lol
    2. Silver Filligree corners. These will be on the SSD's / CPU Block and PSU. (Will be gold plated)
    3. Edge trim. This white trim will be for the grommets where cables go, it'll replace the black rubber.
    Will also be used on the shroud.
    Wish i had more in, will hopefully change tomorrow, and i get start shooting the first video and show you guys some new parts :)
  3. MT. Mods
    6 Apr 2016
    Things have begun to arrive.
    With the help of, Fred, let's get cracking
    Huge thanks to Cooler master
    From the mighty Cooler Master - The V1000 PSU
    Cooler Master Masterfan Pro 140 - Air Flow fans
    Should have more arriving this afternoon.
  4. MT. Mods
    6 Apr 2016
    Another round of deliveries. As usual, fred is on hand to help out :)
    Huge thank you to ASUS for this - ASUS ROG MAXIMUS IX CODE
    ASUS ROG STRIX 1070 OC
  5. MT. Mods
    6 Apr 2016
    Today i have prepped the motherboard and fans for painting.
    These will be painted with the following effect
    The fans were pretty straight forward, 8 screws per fan, and they come apart.
    The motherboard was a little bit tougher as it's not just screws. there's also plastics glues to the back that need removed.
    Quick blast with the heatgun and i got these off with little stress.
    Hopefully be getting these done this week along side the case and some of the watercooling parts ie Rads, Res top and bottom and CPU block
  6. MT. Mods
    6 Apr 2016
    Case has arrived!!!
    From Cooler Master [​IMG]
    The Cooler Master Mastercase Maker 5
    I got to work as soon as the case arrived.
    First i cut and fitted the front shroud (first of 2) You'll see what i mean later
    I then cut the rear I/o Cover thingy and fitted that
    Case / Motherboard / Fans and radiators are due into the auto shop on monday to get flip painted.
    So my next update before then will be the arrival of Alphacool products.
    Excited nwo it's all finally moving along.
  7. MT. Mods
    6 Apr 2016
    A couple more updates today
    Cut and fitted the real tray plate
    I then curved the front shroud to show the PSU.
    Running out of things to do for the time being. Need the case all painted before i can continue.
  8. MT. Mods
    6 Apr 2016
    Update: Case and other bits are going in for a re-spray today, so i pushed on with the shroud, getting it finished.
    lazer cut this one, as i don't want any imperfections.
  9. MT. Mods
    6 Apr 2016
    Bigger update due tomorrow. But today i decided to scrap the window the case came with, and cut my own frame to allow more of the shroud to show.
    Its measured to perfection, so just a case of screw on and be done with it lol.
    Genuine 24ct gold leaf sheets arrived.
    This is the same gold we're going for on the fittings.
    Tomorrow hopefully the case will be returned completely transformed.
    Until then...
  10. MT. Mods
    6 Apr 2016
    I AM SO PROUD!!
    PROUD to bring these photo's to you guys and girls!
    Absolutely over the moon with the paint finish.
    It's rare for me to imagine something, and actually have it, EXACTLY as i imagined. This is a rare moment.
    let me know what you think. I personally love it.
    Parts in photo
    Cooler Master Master Case Maker 5
    Cooler Master Masterfan Pro 140 Air Flow
    Cooler Master V1000
    ASUS Republic of Gamers Maximus IX CODE
    Edit:
    White window frame has been added to the case
    Changed the gold vents on the top to gold
    Currently adding my gold filigree corners.
    not sure where else i'll put them lol
  11. MT. Mods
    6 Apr 2016
    VLOG Episode 1:
    Due to everything being cut down, i will only do 2 episodes.
    Second episode will cover a full timelapse of the hardline watercooling AND a timelapse of plating the fittings.
    Will include other mods.
  12. MT. Mods
    6 Apr 2016
    Today, i've almost finished the shroud, need to let the glues fully dry before i continue with it.
    Need to fill some gaps and then seal the pyrite nuggets into the shroud.
    Fred as always helping out.
    And a video here, showing you exactly how it was done
    here's another video of the paint effect up close
  13. MT. Mods
    6 Apr 2016
    Minor update today
    Using 24ct gold leaf, i covered the front logo to make it stand out more.
    It's a little rough due to the gold leaf being incredibly difficult to work with on an embossed logo.
    Will be much easier for sponsor logo's later.
  14. MT. Mods
    6 Apr 2016
    Watercooling is finally in the UK, got an actual date now, (Monday)
    So i thought i'd share some pictures of the painting at it's white coat (before the gold was added)
    and some other pictures of the finished stuff in a more accurate lighting.
    And these with some sunlight and a white flash
    off to enjoy ''For Honor'' for the weekend, will check back on monday with some updates and some watercooling :)
  15. MT. Mods
    6 Apr 2016
    Today is a good day! Alphacool delivery has arrived
    Huge thanks to ModMyMods, Alphacool and AquaTuning for the support.
    let's kick things off with a picture of everything together in all it's glory!
    And onto the individual parts (some will have GIFS)
    Unboxing video
    Alphacool 45 angled adapters
    Alphacool NexXxoS XT45 280mm Radiatior
    Alphacool NexXxoS ST30 280mm radiator
    Alphacool VPP665 PWM Pump
    Alphacool Eisbecher 250mm Reservoir
    Alphacool Eisrohr 16/13mm fittings
    Alphacool Eisbaer Solo (CPU Block / Pump Combo)
    Alphacool Eisblock XPX CPU block
    There are some other stuff here too, i'll update as and when i can, going to be very very busy over the next few days while i wait for the GPU block to arrive, i will be gold plating around 20 fittings.
    Anything extra will be put into my partners guardians of the galaxy cooler master 25th anniversary project. Logs should be up soon for that too :)
  16. MT. Mods
    6 Apr 2016
    Updates!!
    i've begun work on the parts i want gold that cannot be gold plated.
    So first things first, i stripped down the CPU block
    I then prepped the block with a white coat before going over with gold. This was to allow the gold to be lighter.
    i then went ahead with the gold on the block head
    Once dried, it cleaned up really nice
    i kind of liked the stands in white, so i've kept them white, will need another white coat later tonight, but not rushed
    I also done the reservoir top and bottom using the same technique.
    Radiators are up next, but will need to do this another night.
    So far i'm impressing myself with this.
    Clear silicon mold will be made for the ''ACOOL'' logo on the CPU block to allow it to really brighten up.
  17. MT. Mods
    6 Apr 2016
    BIG UPDATE!
    This weekend i spent 7 hours, gold plating all the fittings from Alphacool.
    7 HOURS!!! I was feeling exhausted by 2am this morning.
    So here's the fittings
    Chrome stripping took the longest, so i didn't video the whole process.
    After chrome stripping them, we left them in water to avoid oxidisation.
    We got bored doing them 1 by 1
    So once they were all stripped properlyt and the chrome had gone leaving a yellowish nickle colour, it was time to start the exciting part
    Will polish up the gold later tonight when i can work up some energy.
  18. Hukkel
    Hukkel James' minion
    20 Dec 2012
    whoa that plating looks reallt nice :)
  19. MT. Mods
    6 Apr 2016
    Will give them a polish later tonight before fitting them to the system :)
  20. MT. Mods
    6 Apr 2016
    update: Watercooling
    It's been a little while, but everything is here now and i can crack on and get this build finished over the next week.
    GPU Block arrived
    I started getting the loop lined up using scrap tubes, to get the size right.
    Next thing i done was re-spray the GPU block to a nice shiney gold to match the CPU Block.
    i then messured and cut a 20mm hole out of the shroud for the passthrough.
    Now that was done, i needed to fill the loop and test for leaks.
