Scratch Build – In Progress COMPLETED - Watercooled CarPC - November 12th. Danish CaseModding Champion! :)
Discussion in 'Project Logs' started by Angel OD, 20 Apr 2011.
  1. LooZypher
    LooZypher Huh!? What!?
    4 Jan 2008
    Man that's amazing...
    'kæft det er sukkertøj ;o)
  2. The boy 4rm oz
    10 Apr 2008
    It has been a while since I popped in on this project and I must say you are doing a fantastic job, keep at it :thumb:.
  3. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    Have to agree, amazing results so far :D
  4. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    In a perfect world, I would have it on my dashboard! :lol:
    Thanks man, it's much appreciated! :)
    Well... There really is nothing but to dive in there and give it a go! :)
    Thanks a lot! :)
    LOL .. Thanks! :)
    I truly hope that I don't have to bleed the system any time soon either! :)
    What will I do to prevent condensation? Not a damn thing! :lol:
    It's been running fine for the last couple of years in the car, I actually never thought of the issue... Gonna just cross my fingers for now! :)
    You never know, I might upgrade some day - But that would mean a completely new build! ;)
    Thanks! :)
    I would agree, but since it my own creation I can't! :lol: Thank you very much! :)
    Me neither! Can't wait to get it done, and in the car! :) Thx!
    Thanks man! Love some danish support! :thumb:
    Thanks! Yeah... Modding really get's under my skin and I just can't seem to stop! :)
    So far? What do you mean? :lol: Thanks! :)
    Just a very small update. I found some sleeving that I bought for my very first mod, never thought I would see that again! But it seems to fit perfectly for the wires for the pump!
    I DID run in to a small problem though... When I mounted the front aluminum piece, I discovered that it actually shorts the board underneath... No harm done though! I was pretty sure I had that covered, but everything can't work in first try! :)
    Unfortunately there has been no mill free to use after hours this week, but hopefully tomorrow I should be able to take off 1mm of it.
    Once that is done, it's time for final pics! :clap:
    C ya soon guys! :)
  5. Cheapskate
    13 May 2007
    Slap some plastic laminate on the short zone and call it fixed.:D
    Some people have to learn to be lazy. That's what I'm here for.
  6. Angel OD
    16 Sep 2007
    I was BORN lazy! I'm working the other way! :lol:
    Actually, I thought about it! But since I had to take dismount it anyways I might as well do it right. Also I dislike the idea that the pointy solderings might scratch their way through the plastic! :)
  7. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    My god that looks awsome:D So compact and good looking with the fluid inthere! I dont know why, but I want to see this anodized in some weird colour:p
    Sorry to hear about the short. At least it wasnt the pump:D
  8. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Good idea - preferably in the same colour as the car it's going into.
  9. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    Now that the beast is water cooled, what are temps ?
  10. antonyand
    antonyand mmm Jaffa Cakes
    5 May 2010
    nice carpc. When ppl said to water cool my pc i thought it'd by way OTT. but dam that looks nice.
  11. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Great mod, I like the water bottle res :lol:
  12. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Luv it....and look forward to the final photos :rock:
  13. Angel OD
    16 Sep 2007
    AMEN to the pump comment! :lol:
    Yeah, I was thinking about anodizing, but not this time. :)
    It's silver, so I'm close! :p
    I actually thought about spraying it the color of the car, as I have a couple of liters left from fixing rust, but since it was not in the plans from the start everything would have become a bit thicker/wider, and with the tolerences I have on this it wouldn't be possible to assemble it! :)
    Well, I can't really tell you! :)
    The pump is connected to the CPU fan socket, and this old mobo don't really have a lot of options. So the pump will start running when CPU reaches 45 degrees centigrade.
    But it will only run a little while, then the temps are down below again.
    But right now the room temp is about 23-25 degrees, and it idles at around 42 degrees, so the pump isn't running at all. :)
    OTT: http://forums.bit-tech.net/showthread.php?t=179763 :lol:
    It IS OTT, but who cares? :)
    BAH! :lol:
    Thanks! :)
    Ty sir! :) Pics from the photoshoot will be posted tomorrow.
    Just a little teaser:
    C ya tomorrow! :)
  14. Nutman
    21 Oct 2008
    Yummy!
  15. Angel OD
    16 Sep 2007
    Sooo... I guess this is it! It's time to say farewell to a mod! :)
    It feels good and it feels bad, but with the risk of sounding full of myself, it sure as hell doesn't feel ugly! :)
    Here you go guys, some pics:
    That's it guys! Hope you like it! :)
    I know they are not the best of pics in here, but i'm not into photochopping and stuff! :)
    peteski and David like this.
  16. alain-s
    alain-s Minimodder
    12 Jan 2011
    :jawdrop::jawdrop::jawdrop:This is just unbelievable pretty, i am in love the the looks of the case Angel Its a shame that u wont see much of it in you're car self. Or u need to install a cam in you're trunk and watch it on a display on you're dashboard :D
  17. David
    7 Apr 2009
    Super job, and a great finished product. +rep
  18. Zorndar
    Zorndar What's a Dremel?
    26 May 2008
    This looks gorgeous, you´ve build a masterpiece!
  19. bulldogjeff
    2 Mar 2010
    That is just unbelievable. I would go as far as to say that 99% of people would be over the moon if that was on display as a main computer and you're going to hide it away in the boot of a car.
    Top modding, yet another superb project. I think this is another build that could be in line for a shot at the MOTY, it really is that good.
  20. Attila
    Attila still thinking....
    22 Feb 2008
    Congrats! :thumb: It's a beauty.
