Case Mod - In Progress (COMPLETED ) Work Log: Casemod THOR.
Discussion in 'Project Logs' started by douglas alves, 2 Dec 2014.
  1. douglas alves
    douglas alves Active Member
    3 Mar 2014
    (COMPLETED )
    Hello people.
    My name is Douglas Alves.
    I am from Brazil.
    You excuse for my English, since I am using the translator of the Google.
    I come again to share the newest project of Casemod that will be in the subject of the THOR.
    He speaks the photos for me.
    My last project here was.
    Casemod Resident Evil (Umbrella Corporation)
    http://forums.bit-tech.net/showthread.php?t=272863
    Here it is going to be the beginning of everything of this new challenge.
    Office thermaltake blushes v71
    When all is taking to pieces the office.
    There is no anything that is not got with the will power, the kindness and, mainly with the love and Humility.
    dedication, determination, and pledge always to do better.
    Thermalatke Brasil
    Ttesporte Brasil.
    Hyperx Brasil.
    Monkey custom Brasil
    Performance Solutions Brasil.
    ModersBr Thermaltake
  2. douglas alves
    3 Mar 2014
    Dismounting and cutting to be modified
    I present the Monkey Custom Brazil.
    It manufactures ends personalized extensors.
    Paracord, very well acts, differential quality of the work and quality of the material.
    Mesh Paracord Importada, conectores of 1st Line.
    Model ARK 30cm and 45cm.
    End 8 pins CPU, End 6+2 pins GPU, End 24 pins MB.
    Potos of a few small modification that was.
    Conclusion of the acrylic ones of the ceiling and parliament.
    Modification of the button Power of place.
    Enough photo step by step, p / to understand more or less.
    Lembando that the work here went to bass with acrylic of 10mm,
    completely manual work
  3. douglas alves
    3 Mar 2014
    Next photos made the modification of USB and fan controller that was on the ceiling and adapted to put on the feet of the cabinet.
    Today post pictures of some more finished parts.
    These pieces are the THOR name. acrylic
    The grid for fan 14cm.
    Symbol that appears on THOR Hammer.
    All made by me manually using micro rectifies, tico tico saw, files and lixas.Não was nothing warrant cutting laser.
    Detail, The letters transparent acrylic 10mm and blue with 5 mm, totaling at the time of cutting 2.5mm ... everything at hand ..
    here is already the grid with blue acrylic 5mm.
    This is the symbol. that appears in thor hammer.
    MADE IN ACRYLIC 5MM. HAND
    Well, one more job ready.
    The logo of the official sponsor Thermaltake.
    Cut into 5 mm acrylic., As was small, it was done several hole with very fine drill with micro rectifies and then made finishing ...
    Detail was for the size of this piece done by hand ..
  4. silk186
    silk186 Derp
    1 Dec 2014
    wow, this looks like a very time consuming build. How many hours have you put into it?
  5. douglas alves
    3 Mar 2014
    How I do it all manually, it takes much yes.
    These works above took me two days ..
  6. bulldogjeff
    2 Mar 2010
    This is proper modding. Straight in and cutting things up, just what I like to see..
    Looks brilliant already.. Nice work
  7. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Muito bom. Sua habilidade é de alto nivel. Eu gostei muito do painel preto. :thumb:
  8. 8-BiT
    8-BiT New Member
    23 Nov 2014
    Amazing work! Keep it up!
  9. douglas alves
    3 Mar 2014
    Photos of today are small jobs.
    Some cuts in the cabinet, for simply not only adorn the cabinet have to cut and modify ..
    I made a stand to place the lighting of the cabinet buttons and will stay beside the fountain.
    as always the pictures speak for me.
    Thank those who came.
    Buttons for lighting, will be on the side of the source
  10. Blaso
    Blaso New Member
    1 Dec 2014
    Nice build!, how do you do to make shiny borders of acrylic?, do you do with the flame method, or polish?. Regards
  11. douglas alves
    3 Mar 2014
    blz staff
    I made a support for headset.
    Acrylic 5mm., Lack put LED UV below, and connect the usb ..
    The middle part is to put some soon.
    All removable.
    Now lack headset to test and take pictures ...
    Using only micro rectifies, hacksaw, files and sandpaper, just ...: awesome:
    As always several, p / not doubt that it was myself I did ..
  12. MarkVarley
    MarkVarley Member
    12 Sep 2014
    That's some nice work there :)
    Sent from my GT-I9505 using Tapatalk
  13. Cheapskate
    13 May 2007
    Great stuff.:D Love the hammer paint on the plexi. That has a nice effect.
  14. douglas alves
    3 Mar 2014
    Thank those accompanying the project ..
    thank you.
    I had to make some cuts in the can and change the front of the cabinet in order to put a radiator 360.
    I made an acrylic support for the radiator to be fixed on the front of the cabinet.
  15. Bartacus
    Bartacus Member
    30 Oct 2014
    That's some fine work! Very nice!
  16. douglas alves
    3 Mar 2014
    Well here begins the cover of fonte.Feito manually ...
    I'm doing differently the cover, in order to bear the watercooler parts.
    And the side of the cover will be temperature sensors, ha idea before was to leave the sample to the sample power supply, but the sponsor has not completed the combined, had to improvise, therefore a part of the acrylic turned blue.
    At the end lack of further finishing. soon ready
  17. Catarun
    Catarun New Member
    7 Oct 2014
    Thats some amazing acrylic work!
    Great job man!
  18. Bartacus
    Bartacus Member
    30 Oct 2014
    ^ What he said! Excellent work Douglas!
  19. douglas alves
    3 Mar 2014
  20. Sanjaya
    Sanjaya Member
    4 Sep 2013
    WOW
    Wow great work mate. and lot of effort. good luck :dremel:
