Development Completely wiping a Hard Disk
Discussion in 'Tech Support' started by Timmy_the_tortoise, 27 Jul 2011.
  1. Timmy_the_tortoise
    Timmy_the_tortoise International Man of Awesome
    28 Feb 2008
    Hey,
    I am trying to install windows on a Hard Disk using a Development Board at work.
    The Disk I am trying to install to has two odd partitions (I think they're related to the windows boot, flagged as "boot" and "msft-reserved") which I am trying to get rid of, since whenever I plug the drive into the Dev Board it just freezes up..
    The Rest of the drive is all unallocated space so I am guessing that that must be what is causing it.
    Does anyone know any way for me to get rid of these partitions so I can just have a blank, unformatted drive?
  2. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Damn tapatalk, didn't do all my post, I'll do it on the computer in few
  3. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
  4. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    fdisk in linux.. p, d
    should be able to get them all whatever they are formatted
  5. Timmy_the_tortoise
    28 Feb 2008
    I got it sorted, thanks guys.
    None of the partition managers I used would let me just delete the partitions, probably because of the flags...
    I managed to reset the partition tables and get it working.
    Thanks again!
  6. Kernel
    Kernel Likes cheese
    29 Sep 2003
    For future reference, you can do the same as in this blog, but instead of USB drive you use the HDD
    Linky
  7. Joshua_Brighton
    Joshua_Brighton What's a Dremel?
    29 Jul 2011
    GParted
    Gparted comes on all ubuntu discs and many other distro's i'd imagine. Easiest way to do it imo.
