Its a psone lcd, I would like to connect it up to a composite (or svideo) input. this is the pinout (from here I assume that socket2>pin1 would need to goto the RCA center pin. Im unsure what the RCA outer should connect to (ground, csync or something else?) thanks
Hi, You can connect the outer portion of the RCA wire to anything that is labeled ground. Keep in mind that Composite is for the most part a 1 pin interface with a sheild wrapped around it. Same goes for the audio wires as well.
