Electronics Composite Video question
Discussion in 'Modding' started by thermoking, 13 Aug 2004.
  1. thermoking
    thermoking What's a Dremel?
    11 Aug 2004
    when using composite video do i HAVE to use the Ground from the video source or can i use one from the power supply going to the display
  2. Sunny-D
    Sunny-D What's a Dremel?
    11 Apr 2004
    i would think you could use any ground, seeing as ive read wiring guides on how to relocate an eject button and use a different ground to activate the eject function.
  3. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    err no, i think you need a common ground for both devices.
  4. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    You should also keep digital and analogue grounds separate, so don't try using the ground from the PSU :nono:
