Compressed Air? Where From?
Discussion in 'Tech Support' started by MiNiMaL_FuSS, 25 Oct 2007.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Anyone know where I can get some cheap compressed air? Maplin want £10 for a can, which seems a little OTT to me.
    Thanks.
  2. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I think £10 is about right. Air is more expensive than you'd think. My sixth form actually gets scented oxygen from hippy internet sites because it's cheaper than buying it from a scientific supplies shop.
  3. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    I disagree about that price. Around here, I can go into a CompUSA or even a Best Buy and find those cans for $2.50. I don't know what similar stores you have over there, but I can't imagine canned air costing ten times as much in the UK as the US.
  4. capnPedro
    11 Apr 2007
    eBay?
    Ummm I get my compressed air pretty cheap; but I have tanks for paintball markers which I can get filled to 3000PSI 0.7l for £1 or get a small SCUBA tank filled at a dive shop and bulk from that.
    But you're talking about the little air duster things, right?
  5. Krikkit
    21 Jan 2003
    Depends what you want it for - I do a bit of modelling, and have a little compressor for an airbrush which was ~£50, perfect for its use, on the other hand, it'd be useless for dusting because the pressure's too low once it's regulated properly...
  6. MiNiMaL_FuSS
    24 Dec 2003
    For dusting, my p180 is pretty hard to get around inside, and dont wanna have to take out the Sycth just to clean it...
    So some strong compressed air would be good.
  7. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    i believe you can buy a small tin of the stuff from jessops, the camera shop. they use it to clear lenses. it's about £5 the last time i checked. but yes, it is stupid, paying for a tin of, well, air!
  8. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Jessops do 360ml 'refil' cans that require a re-usable valve (screws on top).
    I actually checked today and they don't have any of their own-brand ones (were about £6.99 a can, and less than half of that on a staff account..) and alas, their order of 3600 from suppliers seems to have been caught in the Bermuda Triangle en route, like so many things did.
    Anyway, they still have the more expensive (branded) versions. Essentially the same thing, but without being own brand. They're £8.99, and the staff discount is pretty minimal (if anything at all, given that my memory's serving me correctly.)
    HTH :thumb:
  9. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    You can buy a can of compressed butane for 50p, not that it'd make a great substitute, just an interesting comparison.
    BTW, a froogle for air duster throws this up, pretty cheap from the looks of it.
    Edit: Postage is a killer, don't bother :rolleyes:
  10. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Get a can of lighter gas, cheaper and lasts longer. Which is inherently wierd. Do clean outside the house tho. :D
  11. Krikkit
    21 Jan 2003
    It's amazing what going bust can do for your stock tracking abilities... :p
  12. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    get an air horn.. take the top off.. add a tube... sorted?
  13. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Why not get a small air tank and fill it up at a gas station
  14. MiNiMaL_FuSS
    24 Dec 2003
    I've seen refillable cans on ebay, but wouldnt you need a compressor or something to refil them?
  15. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
  16. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    Buy some Dust Off XL on ebay, its perfect for cleaning PC's you get directional straw thing too.
    DustOff XL - £4.99
  17. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    No no, the re-fill cans aren't refillable - they are refils .. Not that they re-fill anything either! It's a bit mis-leading, but the way it works is you buy two parts; the re-usable nozzle that screws on top, and the can. Then you just change the can when it runs out, hence why they're dubbed as re-fills.
    It was about the same at any point within the 18 months I worked for them. Technically they haven't gone bust either..
  18. Shielder
    Shielder Live long & prosper!
    26 Jul 2007
    Not gone bust in the same way that SCO is still a 'leading provider of UNIX technologies'?
    LOL>
    andy
  19. Krikkit
    21 Jan 2003
    True, but closing all your shops and flogging your stock off is practically there as far as consumers are concerned. :)
    Shame though, they're a great company tbh.
  20. johnnyboy700
    johnnyboy700 Minimodder
    27 May 2007
    A cheap and nasty solution is to get yourself a car inner tube and a small tyre inflator (typically about £5) or you could use a track pump (a bicycle pump with footrests and a T shaped handle used for pumping bike tyres to very high pressures). You then fit a suitable bit of tubing over the valve on the inner tube and stick a small nozzle on the other end, put a valve in the tubing for controlling the flow - if you use a gate valve for this and you can have some control over the pressure coming out of the end. This will give you a means of getting compressed air into nooks and crannies and its infinitely renewable - as long as you don't mid the smell of rubber and don't have too big an inner tube.
    It goes without saying, but I'll say it anyway, make sure the inner tube is in good condition, especially if you're using a second hand one and be careful you don't over inflate the inner tube because if it does go bang the results might be quite spectacular.
