Modding computer in ps2 case
Discussion in 'Modding' started by azianese, 14 May 2002.
  1. azianese
    azianese What's a Dremel?
    14 May 2002
    does anyone have the website for the computer built inside the ps2 clear case?
  2. azianese
    14 May 2002
    anyone?
  3. Thorfinn
    Thorfinn What's a Dremel?
    18 Mar 2002
  4. tonyz
    tonyz What's a Dremel?
    17 Feb 2002
    wow, that one is NOT for 56k's. My cable took about 30 secs to get all those pics, i can't even imagine a 56k.
  5. Boggy
    Boggy What's a Dremel?
    3 Jan 2002
    yup that koreamods web-site is not for 56kers like me! i takes about 5-10mins for each article to load and even then half of the images fail! :D dsl rocks:p
  6. Hiren
    Hiren mind control Moderator
    15 May 2002
    That is one the most amazing mods I have ever seen.
  7. Lazy
    Lazy Meow?
    13 Nov 2001
    if you liked that then you should see the mod where some one put a pc in a toilet.
  8. Stew
    Stew Disgruntled Postal Worker
    6 Mar 2002
    though some may say that its a pile of Crap! Ho Ho HO :hehe:
  9. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Yeah that koreamod ps2 is pretty nice, but i have to mention a few things if your thinking about it. I picked up a clear plastic ps2 case to give it a go. Even with my ITX mobo it is super cramped in there. If you notice at koreamod, the guy had to make his own and extend the depth of it by a few inches. So i guess if your gonna give it a go, best bet would be to follow this guys spec.
  10. boycee
    boycee What's a Dremel?
    9 Jan 2002
    now if only there was a way to translate all that i would look around longer :(
  11. Morphine
    Morphine weeee!
    23 Feb 2002
    Hey Scope! if i were to cut all the mounting stuff outta my case and make my own way to close the PS2 case would it fit? how much extra room does the ITX mobo need? I'm thinking bout doing this in a black PS2 case.im gonna make my own back. so i can probably give it another .5cm without modifying the body.that should be all it needs correct?
  12. scopEDog
    scopEDog Minimodder
    5 Mar 2002
    Hmm..well with the ITX board in place it fits *exact*. But you would have to cut the mounting posts (where the screws screw into when you close the case). I also have a laptop dvd/cdr and it will not fit where the ps2 dvd tray is (the mobo gets in the way). On top of all that, i could not find a power supply small enough to fit in the remaining space. You definitely would need to make it deeper by about 2.5 inches. Or i guess maybe make it wider.. I'm just gonna make my own, based on how everything fits. The only way i see that you can do this is with a biscuit/SBC board, but they are too expensive. Good to hear that you'll be in the "fast" lane soon, cable rox :D
  13. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Now thats fugly.............
