Computer making weird noises
Discussion in 'Hardware' started by hellomoto, 1 Oct 2004.
  1. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    I had tape over my PC speaker (POST beep was the loudest I've ever heard) and it disabled in Windows via WPCREDIT, so it wasn't the PC speaker.
    There's the board, and here's the thread I was talking about, the fact that it was related to high vcore and that DFI have been known to use sub-standard components on this board (the vreg IC was rated to 1.85V, whereas the max vcore was 2V) make me pretty sure that it's either the MOSFETs or the toroid/choke/whateveryoucallthems, and seeing as prodding the toroids gently stopped the noise for me at least, I'd place the blame on them.
    Capacitors also start to make really nasty noises when they're on the way out - however they'll also start leaking something awful from the top, and you will notice ;)
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    yes... it will say "kill steve jobs.... kill bill gates.... kill your family.... 28 days, 5 hours, 9 minutes, 32 seconds.... that is when the world will end...."
  3. riluve
    riluve What's a Dremel?
    29 Jun 2004
    Yeah, the speaker is on the other side of the board anyway, it just occured to me that it might be set right next to one.
    Oh well, get me a bottle.
    LOL - anyway, I'll still have to buzz some hardware guys about this monday to see how crazy I am.
    As for capacitors going - just never seen it happen, I hate to ask what you were doing with your equpiment to get that effect - unless you are just speaking generally.
    Oh and still for anyone geting the wrong idea, this is the exception not the rule. Your chips aren't in there all vibrating and making some noise over the roar of even the quietest HS Fan.
    Well, technically, eveything is vibrating at some speed or another, but you know what I mean.
  4. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    I could see why a torid wold make a noise, they have a magnetic field setup in them, inducing another field in the ferrite (duh, how they work) so when the current varies, why wouldn't the fields vary, making tiny movements. Heck in coil guns the coil can contract enough to crush the barrel, especially if it is something brittle. b=But thats just me thinking, and its late, so...
    I know my camera makes noises, it sounds like a hard drive accessing, but that is only when the shutter is open,(when the LCD is on, or when you press the button and hold it half way) I wouldn't think that it would be the focus adjusting since the focus locks when you hold the button half way.
  5. riluve
    29 Jun 2004
    Well you can make a magnet push a train - but this is just a little part with a little current, they're made of rather heavy gage wire, and secured much more than they need to be. Anyway - as I said, day after day, I have freaking MoBo's sitting out on a table - right next to me - not in any case - for years and years, literally hundreds of MoBo's from virtually every manufacturer - never had a peep out of anything except the fans/speakers/motors.
  6. hellomoto
    hellomoto What's a Dremel?
    4 Sep 2003
    It only happens in certain games, max payne 1 and 2, NFSU and I expect its happening because its underload. I removed my CD-ROM drive, soundcard and placed the PSU away from the shuttle and the noise still occurs.
    I think its a small component on its way out
    :sigh:
  7. TMM
    TMM Modder
    12 Jan 2004
    Its a high pitched whining kind of noise?
    Its pretty normal. both my SocketA boards do it (more so the ASUS then the Abit) and i have a Radeon 9200 which whines aswell under load.
  8. hellomoto
    4 Sep 2003
    Yeh, kinda high pitched winning sounds. It doesn't do it on the desktop, loading games. Just in game and in the menu of the game.
    It doesn't do it at all with the game, The Thing.
  9. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    Mine does it sometimes when scrolling down webpages and anything animated etc. It's an ASRock board.
  10. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    since it is only happening in games i think it may b ur CPU fan or gfx fan spinning up for better cooling
  11. hellomoto
    4 Sep 2003
    Nope. Just checked fans. Quickly holded down both fans, didn't make no difference.
  12. dead_man
    4 May 2004
    the whining may b the fans spinning faster on the CPU/mobo/gfx card since it mainly does it during games
  13. hellomoto
    4 Sep 2003
    Its not the fans.
    Should I lower some voltages in the BIOS, that might stop that annoying winning sound?
    Any other reccommendations?
  14. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    i notice a kind of hi pitch hissing asif high pressure air was escaping from a very small hole, when i turn the power switch on on my old rigs 350W PSU.. and when i turn it off it stays for a second but the pitch lessens, as if the pressure is lowering..
    obviously its not air being pushed out of something.. but thats what it sounds most like.. anyone shed light?
