Windows Computer Management won't start
Discussion in 'Tech Support' started by Rapp, 9 Mar 2009.
  1. Rapp
    Rapp Minimodder
    3 Jan 2009
    When I try to run computer management I get this error
    MMC could not create the snap-in. The snap-in might not have been installed correctly.
    Name: Computer Management
    CLSID: {58221C67-EA27-ADCF-00AA00A80033}
    I'm running 64-bit Vista has anyone got any idea's??
  2. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Go Start, Run, and type in compmgmt.msc
    Or just type it into the Vista search box and hit enter
    If that produces the same thing (which it more than likely will)
    Try diskmgmt.msc as well, which is part of Computer Management.
    If that doesn't load either, try a repair install of Windows or a System Restore.
    Or alternatively, if diskmgmt.msc DOES load, then it may just mean the Computer Management window is corrupted, and you can still get to the parts inside in a similar fashion to running diskmgmt.msc.
    Which part of Computer Management are you trying to access? If you go to the Administrative Tools folder in Control Panel, right click one of the shortcuts and you will see something like "%SystemRoot%\system32\taskschd.msc /s"; if you type taskschd.msc into Vista search box it will run the Task Scheduler. Handy huh? ;)
    However, this is assuming the diskmgmt.msc mentioned above works, but Computer Management still won't.
  3. Rapp
    Rapp Minimodder
    3 Jan 2009
    Thanks for the reply, I can get to all of these by just typing them in and they all seem to work fine diskmgmt.msc, taskschd.msc, taskschd.msc I was just after disk management stuff but have sorted that out now. Not sure why I can't access computer management though.
    I was trying to find out why my machine seems to think that it has a floppy disk drive when it hasn't got one and was hoping I could find something in the computer management.
    Have you got any other idea's as to what the problem could be??
  4. Dark_Master_Dragon
    Dark_Master_Dragon Beware of my lair!!!
    22 Jan 2009
    Well
    Maybe its just that your computer management wont load because its kinda slow gice it some time pal ^_-:wallbash::D
  5. Rapp
    Rapp Minimodder
    3 Jan 2009
    no its not that either have left it there for over 10 mins when I was on the phone earlier today
  6. badders
    badders Neuken in de Keuken
    4 Dec 2007
    It may be that you have the floppy drive enabled in the BIOS. Change this to "Disabled" (or similar) if you haven't got one installed.
  7. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    If you are familiar with the registry, try browsing to HKEY_Classes_Root\CLSID and see if {58221C67-EA27-ADCF-00AA00A80033} exists and is not corrupted somehow.
  8. OleJ
    OleJ Me!
    1 Jul 2007
    Seconded.
  9. kenco_uk
    28 Nov 2003
    If it still doesn't want to play ball, try opening an administrative command prompt and run the command:
    sfc /scannow
    You may be prompted to insert your Vista disc.
  10. Rapp
    Rapp Minimodder
    3 Jan 2009
    sorry to bring up an old topic but my problem is still there and I've only just got the time to try and fix it again.
    This is the closest that I have come to being able to fix the problem however the last command didn't work for me. I'm sure it normally says that the dll has been registered if it works correctly.
    http://forums11.itrc.hp.com/service...447626+1244475463070+28353475&threadId=606477
    when I ran sfc/scanow there were some errors with mycomput.dll but they couldn't be replaced as the backup versions were also corrupt.
    HKEY_Classes_Root\CLSID and see if {58221C67-EA27-ADCF-00AA00A80033} is in the registery but I couldn't tell if there was anything wrong with it or not.
  11. capnPedro
    11 Apr 2007
    Try this:
    regsvr32 -s C:\Windows\System32\mycomput.dll
  12. Rapp
    Rapp Minimodder
    3 Jan 2009
    tried that it doesn't seem to do anything, shouldn't it say registered or something if it has worked??
  13. capnPedro
    11 Apr 2007
    Yeah, it should do. TBH I have no idea how to fix the problem, but I was kinda hoping the fix from the article you linked was only not working because it was pointing to the path used by Windows NT.
  14. Rapp
    Rapp Minimodder
    3 Jan 2009
    I had hoped that was the case too, really annoying me now there doesn't seem to be that much information about it that I could find only for win server 2003
  15. mm vr
    18 Nov 2007
    Server 2003 is pretty much the same as XP. Try the solutions.
  16. Rapp
    Rapp Minimodder
    3 Jan 2009
    what about vista though? I have looked into the server 2003 solutions but a lot of the problems comes from installing server related applications
