Modding computer+nitrous=cool?
Discussion in 'Modding' started by vincentnone, 19 Nov 2007.
  1. vincentnone
    vincentnone enthusiast or fanboy?
    19 Nov 2007
    I've looked pretty hard and I can't find any reasonably small nitrous oxide or other canned air sprays for a mod I had plans for
    I'm looking for something that has a colored spray to it, preferably some aerosol form
    obviously this means it probably has to be a liquid
    nitrous seemed the first direction
    but once I did find colored nitrous all I found was immensely big bottles
    I'm looking for the sub-20 oz range
    anything from 4-12oz would be perfect
    so can any of my fellow modders help me?
    the idea goes with a theme for a case I'm working on and I need a green spray, I've figured out how to hook it up so it will spray for a second when I turn on the computer using a momentary switch
    when it powers on it will spray out for a second or two
    after a little work around I'm pretty sure I can get it to work with a smaller bottle
    thus far I've got it working with a 20 oz, and if I can't find any smaller ones I've started on a design to filter it into a series of smaller tubes
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    sounds really cool, what is the theme of the case
  3. weasal
    weasal What's a Dremel?
    22 Jul 2007
    couldnt CO2 be cheaper and easierto get then nitrous oxide.
  4. Rai_Polo
    Rai_Polo What's a Dremel?
    20 Apr 2006
    what would be really cool is if you got it to spray directly onto the fins of a radiator to cool your water like they do on performance turbo system. Now that would be hype.
  5. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Have fun getting 4-12oz bottles of NOS. :/
  6. Cheapskate
    13 May 2007
    Have you tried a Grateful Dead concert?
    ...Oh, wait... Jerry's dead.:waah:
  7. vincentnone
    19 Nov 2007
    the theme of the case is biohazard
    and CO2 would be cheaper but it doesn't like colors and if it hits any components it can seriously mess them up
    and since its meant for show, its going to shoot outside the case not into the radiator (sorry)
    and I've found a solution, a local autozone techie brought out a nice 12oz canister, that he uses for paintball, that was empty and showed me how I can transfer my 20oz green nitro spray into it, though its only good for about one shot, I can fill it up time and time again
    and btw, a random 12oz canister isn't a good idea to store this stuff in, the psi could easily make it explode, grab yourself a certified paintball canister for nos
    they have little paintball pistols that use little nitro canisters of the same size
    and its easy to outfit them with a spray nozzle thus you have the awesome mod
