Thx for all your comments/advise,I think I will opt for the OCZ vertex 120GB or the 80 GB Intel X25-M 2.5 inch SATA SSD for win 7 & my most used programs & 2X1 TB spinpoints for data/storage, i will also forget about raid,and the thermal fan controllers,I may also drop the sound card as I only use sound for games (FPS and Strategy) My Revised PC Antic 900 two with 2 extra fans fitted(the 1200 is a bit big for my desk) Gigabyte GA-EX58-UD3R X58 Intel I7 920 Titan Fernier cooler( or Coolit Domino A.L.C. Advanced Liquid CPU Cooler???) 6 gb(3x2 gb) 1600mhz Corsair XMS3 w/Heat Spreader Be Quiet 750w Modular PSU Dark Power Pro Ocz Vertex 120gb or the 80 GB Intel X25-M SSD 2x 1 TB spinpoints 2x DVDRW Drives Internal 52in1 Flash Media Reader/Writer Microsoft Windows 7 Home Premium (64-bit Edition) OS Graphics Card???? not sure what to go for here,I was thinking of a GTX 275 then a ATI 4890 and now a ATI Radeon HD 5870(need fast FPS at 1920x1200)??? I just ran this through Cyberpower and it came to £ 1504 inc vat and 3 Years Warranty the quote included the ATI 4890 and the 80 GB Intel X25-M SSD and at Computer Planet :£1414 inc vat with 12 months warranty (only changed the OCZ 700W Stealth XStream PSU & G.Skill SATA-II 128 GB SSD & a Zalman (CNPS9900) Blue LED Tunnel Flower)hd4890 At Scan £1,471.78 inc vat and year warranty( changed Noctua NH-U12P SE2 Dual Fan Quiet CPU Cooler,HD4890 your comments would be appreciated thx Tony
Try Chillblast ...they consistently get better reviews for their systems on PcPro etal than Cyberpower, with the benfit of being cheaper! You might also want to take a look at Wired2Fire who also often beat Cyberpower.
with your budget you shouldn't get a 5870 right now you should wait for the new compettitor which is comming out soon and the price of the 5870 will most probably go down so wait till then but you can still buy alot of your pc system now and do you need to buy a new monitor, keyboard and mouse as i am gussing you don't have a nice 24" monitor case lian li b70b http://www.scan.co.uk/Products/Lian-Li-LI-PC-B70B-Black-Full-Tower-Case-w-o-PSU psu seasonic x-750w http://www.scan.co.uk/Products/750W...Gold-90-Effic-4x-PCI-e-8xSata-Cables-The-Best mobo asus P6TD http://www.scan.co.uk/Products/Asus...(x16)-DDR3-2000-1800-1666-SATA-3Gb-s-RAID-ATX cpu intel core i7 920 http://www.scan.co.uk/Products/Intel-i7-920-Socket-1366-(B)-Nehalem-266GHz-Cache-8MB-OEM cooler titan fenrir http://www.scan.co.uk/Products/Tita...plus-HDT-CPU-Cooler-(775-1156-1366-K8-AM2-AM3) ram corsair 6gb 1600mhz http://www.scan.co.uk/Products/6GB-...600)-240-Pin-Non-ECC-Unbuffered-CAS-8-DHX-EPP hdd samsung f3 1TB http://www.scan.co.uk/Products/1TB-...3-SATA-3Gb-s-7200rpm-32MB-Cache-89-ms-NCQ-OEM optical sony dual layer http://www.scan.co.uk/Products/Sony-AD-5240S-0B-24x-DVDR-12xDVDDL-DVDRW-x8-RWx6-SATA-Black OS windows 7 home premium http://www.scan.co.uk/Products/Windows-7-Home-Premium-64-bit-(Single)-OEM sound card if you like your music you should get one asus xonar d2x http://www.scan.co.uk/Products/Asus-Xonar-D2X-Ultra-Fidelity-71-PCI-E-Sound-Card-(New-Version) total with out sound card £1129 total with sound card £ 1215
