Other Computer powers on but doesn't post, keeps restarting!
Discussion in 'Tech Support' started by MarkW7, 22 Nov 2011.
  1. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I've just built a new machine come to turn it on.. it powers on but doesn't POST. It then restarts itsself and GOTO 10.
    Anyone come across this before?
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    you can try and reset the cmos.. it should be a jumper on your motherboard
  3. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I've already tried the battery but I'll look for a jumper.
  4. ReD ÅLeRt
    ReD ÅLeRt What's a Dremel?
    4 Jun 2002
    I had a very similar thing happen when changing a radiator this week. Turns out I had a fun that was shorting the board out. Try unplugging everything non essential and trying it adding one thing at a time. Takes ages, but it will identify the problem.
  5. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I took the mobo out of the case as I suspected that, next step I think I'll take the PSU out and just try them both together.
  6. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    What are the system specs? It might be a known issue with your motherboard or some other component.
    MarkW7 likes this.
  7. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
  8. debs3759
    10 Oct 2011
    1600 MHz and faster ram should run fine at 1333. In fact, the BIOS should set it to a supported speed by default.
  9. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    We can rule that out then although we can't reach the BIOS yet.
  10. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Take out one stick of ram, and try it with a known good PSU. Make sure all components are seated properly.
  11. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Tried with a known working PSU.. same problem. (So the PSU is fine).
    It's now either the RAM, the Mobo or the CPU all of which are new. I don't have a spare CPU so I go about taking about my Mini server for the DDR3 RAM - Wallah! boots.
    I had it all cable tied in as well, meh, that's going to have to be re-done and I'm going to have to break this to the client!
    So the issue was the RAM was 1600MHz and the board only supports 1333MHz max.
  12. Zoon
    12 Mar 2001
    Have you tried the RAM in a known good motherboard? It sounds like you so far have tested good RAM in the mobo, but not the other way round yet?
    I ask because there's no reason any motherboard should reject RAM which is too fast. Since the days of SDRAM I've been running PC133 at PC100 for example!
    Generally;
    If the ram is good - but incompatible - you'll get error beeps.
    If the ram is faulty - or there is too much for the system to support - you'll get a blank screen, and possibly reboot beeps.
  13. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I haven't tested the 1600MHz RAM, nope, the only board I've got that takes DDR3 is the MicroServer is tidied away. There were no beeps at all just powers up, reboots, loop.
    This is a client build, he's just gone and ordered 2x 4GB Kingston 1333MHz RAM for £36 that'll do the job and I'll just give him these others back.
