Displays Computer randomly drops display
Discussion in 'Tech Support' started by silk186, 12 Aug 2019.
  1. silk186
    silk186 Derp
    1 Dec 2014
    I have two displays connected to the desktop. The Dell monitor is connected by HDMI and the TV is connected with a DP to HDMI adapter. The TV is seen as the primary display. After waking from sleep, sometimes the Dell monitor doesn't connect and displays no signal. If I turn on the TV it displays correctly.
    Unplugging the HDMI/DP does not detect the monitor and a restart is required.
    More recently, when I turn on the tv (second display), Chrom will display black. I can open other windows fine but need to restart Chrome.
    Does anyone have any idea what is causing these problems?
    I didn't have these issues with my last monitor.
  2. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    If the Dell monitor has a DP, connect it with a decent quality DP cable and just use a straight HDMI cable to connect the TV.
    This will help you rule out cable and port issues.
  3. silk186
    silk186 Derp
    1 Dec 2014
    I wish it has a DP port. It has a single HDMI and USB-C
    That's why if use a DP to HDMI adapter for the TV which it never drops.
    I wish I could set the Dell as the primary display but it seems it isn't possible for reasons.
  4. Sentinel-R1
    13 Oct 2010
    What's the model number of the Dell?
  5. silk186
    silk186 Derp
    1 Dec 2014
    Dell S2719DC
  6. Sentinel-R1
    13 Oct 2010
    Try a DP to USB-C cable from Amazon? If it doesn't solve the issue, return it?
  7. silk186
    silk186 Derp
    1 Dec 2014
    It's worth a try.
