Windows Computer shuts down and restarts intermittently
Discussion in 'Software' started by joodee, 10 Jul 2005.
  1. joodee
    joodee What's a Dremel?
    3 Jul 2005
    I have installed a new video card-Radeon 9550 and a new hard drive on which I have loaded Windows XP SP2. Now the computer keeps shutting down and restarting. I have checked that I have the latest drivers. Any ideas on what might be causing it? On restarting I get the message that the system has recovered from a serious error.
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    What PSU do you have? It might not be able to handle the new hardware
  3. joodee
    3 Jul 2005
    How do I find out what PSU I have? My motherboard is a Gigabyte GA-7DXR with amd XP 2000 CPU. Thanks.
  4. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    Take it out of the case and look. Write down the Make/Model and the wattage. :)
  5. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    PSU = Power Supply Unit. The big box at the upper back of your tower (usually).
    They all should have a sticker on them w/ make/model/wattage.
    There are online calculators that you can enter all your comp. equipment into and get a total wattage used number. Your PSU obviously has to output at least that much wattage.
