Modding "computer wire"
Discussion in 'Modding' started by Cannon^Fodder, 25 May 2004.
  1. Cannon^Fodder
    Cannon^Fodder What's a Dremel?
    13 Feb 2004
    Hey there, can anyone tell me where i can get red/black wire for the inside of computers from. I go to hardware sites, all the "computer wire" is stuff like ribbon cable and network cable, and i'm not sure what resistance etc the wire needs to be...
    A maplins code or similar would be really handy :)
    btw i know u can buy it from "modding sites" but the prices are blatantly trying to overcharge muppets like me who can't find what they want on maplins :D
    Sean.
  2. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    You can use standard wire.
    If you're pulling alot of current you can get a thicker gauge multicore like from your molex connectors in your pc, you probably wont need it though.
    Wire is generally nothing special.
  3. Cannon^Fodder
    13 Feb 2004
    lol yea but where can i get it from ?
    i've got plenty of old PSus lying around, but for some mods i'm doing this summer, i'm gonna need fairly long lengths of the stuff.
    cheers for the reply anyway
  4. trigger
    trigger Procrastinator
    22 Mar 2004
    I couldn't easily find any online either, so I just went to my local Basic Electronics shop and asked for some generic wire. It's quite happily powering my internal LCD now (so far!)
  5. Madoron
    Madoron What's a Dremel?
    24 May 2004
    Hey again Cannon^Fodder... Pop down to your local maplins... they are all over the place... heck there are 2 here where I live just in the city centre! They have loads of the wire you are after! :) They also sell the heat shrink I am using ATM LOL :)
    Anyway hope that helps!
    Always,
    Mad.
  6. <A88>
    <A88> Trust the Computer
    10 Jan 2004
  7. Morphine
    Morphine weeee!
    23 Feb 2002
    your looking for 18guage wire. Same stuff as car speaker wire.
  8. FuzzyOne
    FuzzyOne
    19 Sep 2002
    I use bell wire for odd bits and bobs you can get this from b&q very cheap
  9. Blood
    Blood What's a Dremel?
    4 Jan 2004
    Bell wire from maplin , bl07 and bl00 , i work there , i know :)
    those are black and red , 10 metres of both ,.
    ideal
    thas wha i use
  10. Cannon^Fodder
    13 Feb 2004
    cheers guys, and thnx alot blood :D
