computer wont load up windows xp pro sp3
Discussion in 'Tech Support' started by pksjaveed, 10 Aug 2008.
  1. pksjaveed
    pksjaveed Nmodz: modding the world
    28 Apr 2008
    well here is my specs first:
    evga 650i ultra t1
    256mb ram
    80 gb sata drive samsung
    30 gb ide drive samsung
    hp DVD/CD reader writer
    Intel p4 processor lga 755
    OK my problem is that it loads the kernels and drives and stuff but then its get to a blue screen and stops and at the bottom it says starting windows setup but it doesn't do anything for like a minute , then after it goes to another screen and it says windows executive setup but it doesnt do nothing for about 5 seconds and finally it goes to the stop .. an error has occurred etc. etc. ...... i thought maybe its a hardrive problem with the sata so i changed it to another drive i had laying around but still the same problem :wallbash::wallbash:
  2. Golygus
    Golygus Minimodder
    9 Oct 2003
    test the ram (use summit like memtest)
    test the HDD's (use the manuf. progs)
    try a different PSU
  3. thebestnews
    thebestnews What's a Dremel?
    2 Jun 2008
    Hi, did you write down the STOP message? It is usefull in finding out the cause of the problem . . .
