News Compuvision DIY Water Cooling Equipment at MODTHEBOX
Discussion in 'Article Discussion' started by GreatOldOne, 27 Jul 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    MODTHEBOX has a review / article that discusses the pros and cons of putting together your own DIY water cooling rig with off the shelf parts - rather than going for a single box solution that is becoming increasingly popular these days:
    "Water cooling is as much about silence as it is about performance. For some users, performance even takes second place to the goal of an ultra-quiet rig. As such, another key area to investigate is how loud the pump is. The noise generated through the pumps vibration can be minimal, or can be as noticeable as a mid-ranged rotary fan. Some pumps are significantly quieter than others, and some can also be fitted with vibration dampeners to lower the total noise levels."
    More watery goodness here
Tags: Add Tags
