Concept PC H-1 Complete.
Discussion in 'Project Logs' started by Defyant Mods, 25 Jul 2005.
  1. cc rass
    cc rass What's a Dremel?
    28 Dec 2004
    Very nice idea and the case looks great right now. Keep up the good work :dremel:
  2. Love it man, just love it! Top-notch work as we all expect from you!
  3. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    The Coolermaster Aquagate comes with a variable fan contoller for the radiator, the best place to fit this was @ the back of the case below the dual exhaust fans.
    CM even supply a sexy little silver knob for a pro look :)
    With the bulk of the rear wiring finished it was time to move onto the the front of the case.
    The Matrix orbital LCD is screwed into place and the atx power switch and leds are wired up
    Holes are drilled and msesh on the innner front wall this will allow air into the motherboard chamber ofthe case.
    With the front wire loom can be passed thru the front wall and the Motherboard Panel can be "slotted" into place!
    the top roof separator can be bolted down and the wires passed thru a precut hole for the Radiator fan.
  4. Defyant Mods
    14 Sep 2004
    Next step is bolt the CM block/pump onto the CPU... and bolt the board into the case.
    With the board and water block/pump in the Top Unit can be bolted on containing the 120 Rad and Fan.
    The hole Top Rad housing slots into the front then drops down at the rear were its bolted down
    the Water hoses are fed thru 2 pre cut holes and the wiring is attached.
  5. Defyant Mods
    14 Sep 2004
    The back section is added, hoses connected water added and the fan is tested.
    Low
    medium
    High
    its good to see the Fan drawing air well.
    The original idea was to also mount the HDD behind the "backwall" on the underside with the CDROM and PSU.....
    But this is something that i will want to change as needed....and as this pc will be used as a webserfer for the wife...i thought qik access far outweight
    any athetical beinifets....
    How ever! i come up with a nifty way of mounting the HDD into the base of the unit.
    Using some left over Caddy screws and rubber grommet vibrating dampers i managed to solve the problem of not having the HDD sit flat on the floor...
    allowing some air to pass under and not cook the hdd.
  6. Defyant Mods
    14 Sep 2004
    Next was to attach some sexy feat, for now i'll attach these using thy'r adheasive pads 2 more will be brought later and all 4 will be bolted on.
    With the feet and hdd moutning out of the raod last was to add the front Duct and bolt the front facia on.
    The ATX conn came up short.... for now! ive usued a small exension and painted it black to help hid its ugliness... but this will be
    fixed as soon as i can purchase a newer longer cable.
    H-1 is really starting to look like a PC! the internals are all connected all the panels and facia are secured.
  7. Defyant Mods
    14 Sep 2004
    All thats left to do is fire the PC up laod windows and setup the stuido for some shots!!!
    Adding the font frosted plex panel realy changes the look of the PC..i cant wait to try this with different colored frosted plex panels.
    Addding the side panel with the "smoked" tinted window.
    Testing the slot loading DVD...
  8. Defyant Mods
    14 Sep 2004
    Final shots for now....
  9. n00b
    n00b What's a Dremel?
    17 Jul 2004
    Sweet.. I would've wanted to see it with orange lights, but whatever. Looks awesome!
  10. Firefox90
    Firefox90 What's a Dremel?
    14 Jul 2005
    Simply awesome. You have really gotten me into the frosted plexi. I am now integrating it into my case.
  11. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    Lovely....
    The only possible critique I can think off is that the light of front LED is not spread enaugh. But that probably looks better in real life since you most likely took that picture with long shutter speed thus making the source of the light stand out more.
    This case has a very strong character.... It looks so steady, and kinda reminds me of old school...
  12. Jipa
    5 Feb 2004
    Looks extremely futuristic to me... I love it!
  13. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Case looks excellent very inspiring fascia design aswell.
  14. furqan
    furqan What's a Dremel?
    2 May 2004
    Wow! that looks amazing expecially with the blue
  15. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    OK I officially love your style. There is truely not one thing on that case that I don't like.
  16. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Awesome
  17. das_mod
    das_mod What's a Dremel?
    13 Jul 2005
  18. keir
    keir S p i t F i r e
    5 Oct 2003
    amazing, thats one awsume looking web surfing machine.
  19. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Great job looks awesome!!!!
  20. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looks sexa :)
