ive read somewhere that the lian li pc 60 case now come with bloo leds and a blow hole. can anyone confirm or deny this and if they do doe the pc65 come with them since it is basically teh same case.
my mates got a pc 60, and ive owned a pc 70. neither of which had a blow hole, but they did have red and bloo led's youll have to check it out with the supplier whom your buying it from. why not use the wonderful feature of e-mail
a standard lian li case does not come with a blowhole or blue leds. You might be looking at some custom cases that some sites mod and sell on at a higher price.
No, those are teh new pc-6083 adn 6085 variants. go to the lian li homepage and give a look-see: http://www.lian-li.com/product.php?action=viewPrd&online=1&order=1&keystr=&pcid=32&secid=&cur_page=2
I just got a PC-60 and here's what I have in there: - two 80mm fans on front - one 80mm fan at the back - one 80mm fan on top with slits that form a square (not mentioned on the lian-li site) - the power and reset switch was not on a square bevel thing with oval indicator lights (as seen on the pic) with water clear LEDs. I wasn't able to see if they were blue because I replaced them with some broght blue LEDs I have before plugging the case in. I'll check if they were blue once I get home.
you have just awnsered your own question then. These must be a new kind and have a different code so the pc 60 will look like the one above.
cheers guys you have been a great help. ive just placed me an order for a lian li PC65 with the overclocking store so hopefully ill get it in a few day's. woohoo i cant wait. it will be good by full tower chieftec, hello nice shiney lian li . ill just have to remember to lie about the cost to my parents to save 'waste of money talk' . all ive gotta do now is get me a cc tube and possible a window transfer .
Ok, the PC-60 I have (the one on the pic I posted), had water clear bright blue and red LEDs for the power and HDD activity.
for some reason parents don't understand why i spend some much money on my pc. Its my money and i earnt it.
I told mine that everything I do with my money is better than wasting them on drugs, cigarettes and alcohol. So they never bothered to ask again.
got my case (PC65), didnt have the blow hole in it but its got the blue and red leds. Its sweet how the red actually looks purple cus the blue light is always on . nevermind there was somin else to surprise me when i took it out the box i noticed that there was a lian li temp sensor in my top drive bay which i didnt ask for, they aint gettin it back .
i did that as well but they sill give me funny looks when i say i am ordering something expensive. Now i have my own debit card i don't have to tell them i am ordering anything.
