Can someone please tell a "confused silver surfer" what the red writing is about, reguarding fitting an AMD AM3 CPU to this mother board, and what effect it would have http://uk.gigabyte.com/products/product-page.aspx?pid=3645# Cheers.
Depending on the processor you install it may not run at its optimum speed. In all honesty you probably won't notice a difference. Depending on what you are looking to do and what budget you have there may be better options
