Peripherals connect two PC's per headphone in one network
Discussion in 'Tech Support' started by Xir, 13 Sep 2020.
  1. Xir
    Xir Well-Known Member
    26 Apr 2006
    My kids play on two PC's in my house, in different rooms.
    I'd like them to talk to eachother, using two headsets.
    Preferabbly, I'd like to NOT use an internet based service. They should just stay on the internal network.
    All I've found are the likes of Discord or Teamspeak, which both require registration and internet connection and I'd like to avoid that.
    Is there a way?
    Best regards,
    Xir
  2. enbydee
    enbydee Active Member
    10 Jul 2014
  3. modd1uk
    modd1uk Well-Known Member
    4 Sep 2006
    Teamspeak should work? Like if my internet dies I can still join my teamspeak server on any of my PC's....
  4. Xir
    26 Apr 2006
    You can run an extra local Teamspeak server, just like Mumble...
  5. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I mean I'm white and nerdy so I'd just be buying them a pair of those PMR VOX 2-way radios that motorbike instructors and body guards use. Will make them really appreciate discord when they finally do get it.
  6. andrew8200m
    andrew8200m Well-Known Member
    4 May 2009
    host your own TS server on an old pc not on the internet but on the local network?
  7. sandys
    sandys Well-Known Member
    26 Mar 2006
    Baked bean can and string :p
