Networks Connecting 10mbs to 100mbs
Discussion in 'Hardware' started by Adam, 30 Mar 2002.
  1. Adam
    Adam Minimodder
    26 Jan 2002
    I've got a 100Mb/s network which I want to add another machine to with a 10Mb/s network onboard. There is only 1x PCI slot in this machine which I need, so is it possible to connect the 10mb/s to the rest of the network?
  2. corvette
    corvette What's a Dremel?
    27 Nov 2001
    u can but if ur runnin a hub the hole network well slow down to 10m so ur network will be hella slow same if its x-ova ur network will slow down
  3. Adam
    Adam Minimodder
    26 Jan 2002
    I've got a switch but when I plug it in, it doesn't see any of the other computers - but it does if I use a 10/100 PCI card in the PCI slot.
  4. corvette
    27 Nov 2001
    i dont no bout not seeing others but useing a switch doesnt matter ur hole network will slow down to 10m
    have u got file and print shareing on mabe that will help um do u have optian ip on auto or did u specify 1
  5. Adam
    Adam Minimodder
    26 Jan 2002
    It is supposed to assign the IP automatically but it doesnt get that far, it can't ping any other machines either. I think I'm going to use this machine as a smoothwall instead.
  6. corvette
    27 Nov 2001
    ok try assianing ur own ip it should work also ur other network cards should be on auto detect speed i dunno how to do it but u hsould try this ip
    192.168.1.X X mean the amount of computers on ur network
  7. Phil
    Phil What's a Dremel?
    19 Jul 2001
    it's got nothing to do with IP addresses it's because of the switch/hub most likely
    Please state exactly what make and model switch/hub you have
  8. therider
    therider What's a Dremel?
    11 Mar 2002
    is your switch 10/100 switching compatible?
    There is no reason why it shouldnt work. The setup is probably the problem.
    On the machine with the 10Mb/s card ping the local ip 127.0.0.1
    i.e. C:\ping 127.0.0.1
    If you dont get any responce the onboard nic is dead or disabled.
    ride
    or...
    USB 100Mb/s adaptor? as a possible solution?
    http://www.linksys.com/Products/product.asp?grid=31&prid=126
    I got this one for my PS2 tiny hawk 3 on broadband nice!
  9. Adam
    Adam Minimodder
    26 Jan 2002
    I think it must be dead. Strange though coz the light on the hub comes on when the computer is on so it can't be completely dead. I've put a 10/100 PCI card in and taken out the sound card, and as soon as my Fast 24 account is set up and aol cancelled then it's going to be a smoothwall.
  10. therider
    11 Mar 2002
    did you ping the 10Mbs card in the machine? what was the responce?
    ride
  11. Adam
    Adam Minimodder
    26 Jan 2002
    I couldn't ping the machine from any other machines. I had already put the 100Mb card back in when someone posted about pinging 127.0.0.1. It's not that important, I am getting some more bits on monday to build an MP3 box.
  12. Phil
    19 Jul 2001
    no no, you don't want one of them
    because the MOST it will do is 12Mbps, and only then if you're lucky.
    most 10Mbps cards are faster than USB adapters.
