Connecting a SN41G2 Firewire to a EpiaM1000
Discussion in 'Hardware' started by Cyberbob:-), 5 Sep 2005.
  1. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    Hi guy's hope someone can help,
    I've got a SN41G2 Case and I've installed a Epia M10000 Motherboard.
    I've connected the USB and sound from the front panel straight to the motherboard no problem, used the cables that came with the SN41G2,
    But the firewire is the wrong way round, won't fit on the motherboard, does anybody know the pinout on the front panel on the SN41G2 for the firewire??
    Please?
    Thanks
  2. Krikkit
    21 Jan 2003
    Well the most informative thing I could find was this pdf manual for it. If you can differentiate the USB pins and Audio connections out of the list on page 33, you'll be sorted! :)
  3. Cyberbob:-)
    Cyberbob:-) Member
    16 Jun 2002
    Thanks for the link to the manual, that has helped me.
    But I still need the pinout from the front panel of the case...If anybody knows...Thanks
